13:1 Compression 3.3L cam'n its ass off
zak
east of Hartford
1.5 mm is about 0.06 inches, that part is ok.
The problem is swinging the radius from the ID of the throttlebody into each plenum, you won't be able to duplicate the size of radius that is there stock, it will have to be much smaller. Aerodynamically, this will cause flow separation and vortices, etc. This will hurt flow.
You might be able to fashion a spacer that tapers from there 75 mm t body down to say 67 mm and use part of the spacer to start swinging the radius. If you subtract the area of the butterfly cross rail I bet the total areas would be close - you get the increased flow area of the 75 mm but away from the butterfly you don't need it. A taper on the adapter of 4 to 11 degrees would be in the right range.
This may seem like splitting hairs to some folks, but look at any discussion on head porting and the emphasis on keeping the short side radius stock, or making it even larger, is a recurring theme for a reason.
intimdatr
Got Cams?
Jefferson City, Missouri
Ahhhh. I see what your saying now Zak. And it makes sense. Would it hurt flow to some how create a divider that help control even flow into the tanks? But Also is that not the job of the equalizer tube on the far end of the Intake's job?
zblackbeast
SHOtarded
Omaha, NE
Funny, I was just on the phone with Zach and told him the exact same thing. Ha this is the first I've seen of this too. :)
But really, I think if you can smoothly get the air to transition around the various parts of the intake path and keep those pulses correct you'll see a gain. Is it worth the amount of work? Maybe not, but when you n/a on small displacement v6 every bit counts!!
Irish Pride
Irish Inside
MusicCityUSA
If you have the spare parts, the ability to do it, and the willingness to put in the time and effort then have at it. Its either going to work or it not. Worst cast senerio, he has to put a different intake/TB on the car.
zach44102
BIG TURBO
Georgia
Gutted butterflys
F FB81 419B 8293 A021E8347000 437 00000039D3F35615
I ended up port matching the butterflys to the tanks. I didnt take pics of this because it was not pretty and I was disappointed with the work. But you can see how much material needed to be removed.
F A090 4214 9B82 4938F5D9D31E 437 00000039D88D8987
2 A407 4F08 B108 97D6070C080F 437 00000039DBCDD085
6 5854 4E06 B788 711A74913F16 437 00000039DF5F2D69
A 8225 493A 87F7 681CB54D2626 437 00000039E8F53882
7 AE5B 44A4 A57C DD473DC6F1E7 437 00000039E359E6FB
zach44102
BIG TURBO
Georgia
I will take better daylight pictures another day, the lighting was not best for a Iphone.
The motor should start being assembled around next weekend. UPS is bringing me a whole bunch of stuff..... (221 pounds of stuff according to them)
zach44102
BIG TURBO
Georgia
Pulled the g3 subframe today. Going to strip it and paint it and make sure everything is sparkly clean.
 03AA 4175 84A2 17B6B690D3B6 1432 0000018AFF30C23D
Rubix
Is that purple paint any kind of special high temp stuff or just regular spray paint? I love it man :thumb:
zach44102
BIG TURBO
Georgia
Just regular paint, no high temp stuff. The purple has about 3-4 coats of clear. The black has about 9 coats of clear lol
zach44102
BIG TURBO
Georgia
The 2 key components to my build should be at my doorstep within 36 hours. Pics soon to come.
