Turbo Failure / Upgrade
BradM
Interesting. I would think your leak test should have detected an intake leak as the throttle blade is not a perfect seal (and has a hole in it if I recall correctly) but I'm not sure how you tested the charge pipes. Do you have a valve that's hanging open? What's your blow-by like?
usmc363
Tennessee
Compression test was good, nothing low and the UPR catch can was normal.
Side note: I drained the intercooler last night, about a teaspoon of oil came out.
BradM
I think if you had a big enough leak at the intake to cause no boost, it would run like crap with such a big vacuum leak. You can always smoke test (or pressure test) the intake before you rip into her.
usmc363
Tennessee
True, it idled and ran fine, and the gauges didn't show an excessive vacuum leak. ugh.
Forgive my ignorance, I'm used to pushrod V8's..All of the intake valves would have to be closed in order to put pressure in the intake and expect it to hold though, I don't know much about the valvetrain timing of the 3.5 to know if that would be possible and would assume it would just go to the exhaust (both valves open with timing) or possibly crankcase and add pressure there, which would probably just blow right out the oil feed/drain tubes that are out since the turbos are out.....right?
BradM
Don't worry, I'm a V8 guy too (but it all works the same). If an intake valve is open, the pressure goes to the cylinder. The exhaust valve should be closed so you'll only get some leaking around the rings (blow by). If the intake valve is closed, any leaking would be through the valve stem seal (also blow by). But I cannot imagine enough ring blow by or valve stem blow by to cause no boost. I wouldn't jump to pulling the intake just yet IMHO. Have you looked at your 2 bypass valves? I assume you kept them in for your leak test but did you electrically disconnect them and see if boost builds?
usmc363
Tennessee
I know that blow by (leak down) is different from compression check, but I would assume that I would see a low compression reading on a cylinder if the rings were shot. I agree with you as well, I don't believe that would be enough to have a no boost situation. Yes on the BOV, inspected the rubber diaphragms, looked good. They were in for the pressure test and held 20psi, then tested with them unplugged and driving, still no boost, then I put two brand new ones on, still no boost.
BradM
If it were me, I'd wait for the new turbos and see where you're at after the install. Maybe it will self-cure :) Sometimes its good to take break...you've hit all of the obvious stuff.
usmc363
Tennessee
Got the turbos back in, installed all new EPP piping as well as the oil cooler upgrade. Boost is back with the terrible exception of surging between 1-18psi in WOT. I believe I have an oil contaminated intake MAP sensor. I put a stock one in it and went back to a stock tune and it ran ok. Just ordered a new 2.5 bar MAP from unleashed (I have 2.5 Bar tunes in the LivewireTS). Going back and forth with MAP part numbers and revisions was a biotch let me tell you. Will report back.
Boochy47
Michigan
Hey guys just noticed getting cool air on passenger side when heat is on ?
Boochy47
Michigan
I was gonna have Machanic see why I get smoke in idle park once and a while
kryptto
South East, Florida
Boochy47
Michigan
Damn I wonder what cost will be smh idk why I fall in love with my cars still better then a woman tho
usmc363
Tennessee
Welp, the long road is over. Got the new MAP sensor in and I have boost. Reading shows approximately 22 psi assuming this is pre-throttle body MAP (Digital readout from LivewireTS) and approximately 16 psi in manifold (mechanical gauge readout). It's dirty, but here is the most recent pic.
Screenshot 2023 10 02 092457
BradM
So this all came down to a bad MAP sensor?
shootinirons
