2013+ Shocks on a 2012 SHO???
Joshw0000
North Carolina
Now that I have your attention, read these 3 posts.
I'm looking to replace / upgrade my shocks / springs. I think I've settled on PP shocks / struts with H&R springs.
I'm having trouble finding the correct part #'s to order. Can someone help me out?
Also, if anyone has this setup or something similar, I'd love your feedback. I understand it'll drop the right height about 1.5" and it'll be slightly stiffer. Hopefully it's not TOO firm or low for daily driving. I'm just tired of the soft / worn out factory suspension.
Sent from my Pixel 8 Pro using Tapatalk
Joshw0000
North Carolina
If anyone with a 2010-2012 PP can post the part #'s from their suspension, I'd be super grateful.
Joshw0000
North Carolina
This is what I have at the moment. I believe most are discontinued (replaced with newer parts), but for all I know, the previous owner could have installed suspension for a SE/SEL.
Front Right
4a1561f3d49b6480caa39df4b36e3019
Front Left
B136e5c50a97f114fb2f4e137249e553
Rear Right
01535c0ee60be23ca8ff3d54e81989fb
Rear Left
0f1b1cbeb27e51dc89db7120bb835739
kryptto
South East, Florida
I have my old rear I will take photos of for ya. I think I have my OEM struts packed away. you will have to thank me when I undig them
out.
kryptto
South East, Florida
10000054151000005414
I only grabbed first strut there is a left and right and the rear shock for a 14, good luck
Joshw0000
North Carolina
Everything I've found so far in terms of PP Struts are for the 2013+ model. Part #'s:
AST12321 (Front Left)
AST12323 (Front Right)
DG1Z18125F (Rear)
So when I enter my car for compatibility (2012), it says they're not compatible. Has anyone installed them on a 2010 - 2012 model? Do I need to modify anything or purchase additional parts?
Joshw0000
North Carolina
Clickbait.
Here are the part numbers I have for reference (2013+):
(FR): DG1Z-18124-X
(FL): DG1Z-18124-Y
Rear: DG1Z-18125-F (x2)
Mounts: DG1Z-18183-B (x2)
Thanks, and sorry for the click bait. I've renamed the thread a couple times as I change directions of my search.
Those are all for the 2013+. Do you have any experience installing them on a 2010 - 2012 SHO?
Joshw0000
North Carolina
Front struts are not interchangeable between 2010-12 and 2013-19. The design is completely different.
Rear seem to be interchangeable.
2010-12
2013-19
Good point. Every site has the rear listed as incompatible with my car so I'm assuming there's some subtle difference with them too.
Joshw0000
North Carolina
Rock Auto shows a few rear shocks as the same for all years.
2010-12
2013-19
Hmmm..... What would you do?
Mix and match front / rear shocks (PP rears, OE Spectrum / Monroe / etc front) with H&R springs, or just get a set of coil overs (Godspeed, Megan, BC).
I've never changed the factory suspension, or had to replace the stock suspension, on any car I've ever owned. It's sorta uncharted territory for me but I plan to daily drive this car at least a few more years. Plus the wife is fussing about replacing the suspension on her Explorer and I've got kids coming of driving age, so now is a good time to get my feet wet.
I'm sorta worried if I mix and match shocks somehow I'm going to end up with an uneven ride height. Maybe that's not even possible, lol. If I went with coilovers, Godspeed and Megan are reasonably priced but maybe that speaks of their quality. BC is proud of their coilovers.
Joshw0000
North Carolina
I think I've talked myself into the Godspeed MonoSS coilovers for the adjustability. I'll probably set the ride height as high as it'll go and adjust the dampening to my liking. Probably mid level for the rear and forget about it. It'll be nice being able to change the front as needed.
Anyone have good or bad feedback about them? Anything else I should buy while I'm there? I replaced the front lower control arms a year ago.
Sorry for all the indecisive posts and thanks to those who've offered help!
Majestic
For orders / shipments? Or for recommendations? I'll probably order from Amazon honestly, if I go with the coilovers.
Their lack of actual customer service and idiotic return policy is why I will never use them again. I will use their parts lookup and then order from Amazon. If (when) the part is incorrect, it's super easy to return with Amazon. RA charges you to return a part, even if they damage it or send the wrong part.
Joshw0000
North Carolina
Ordered on Amazon! I'll post some before / after pics of the height when they come in.
Joshw0000
North Carolina
My kid has a tournament this weekend so it may be 2 weeks before I can put these on. The suspension (pun intended) is killing me.PXL 20251013 180048448PXL 20251013 175859104
Joshw0000
North Carolina
Hey guys, I'm about to start installing those coilovers and noticed that the back of my car sits about 5/8" to 7/8" lower than the front.
The front (both sides) sits 29.5" to the ground while the back sits 30-3/8" (left) and 30-1/8" (right). The difference in the back could be because of the subwoofer in the right side of the trunk. I'll account for that with the coilovers.
But my question...the front and back should be level, right?
Joshw0000
North Carolina
Quick update....I've been working on these on and off for about a week and a half. The front is installed and I think I have them adjusted to my liking. I finished the rear passenger last night and I hope to finish the rear driver tonight or tomorrow. While I worked on them, I've done a lot of other things too:
New front brakes (had to replace a stuck pin/boot)
Coolant drain / fill
Transmission drain / fill (funny story - I accidentally pulled the cv axle out which led to this one)
Air filter clean (why not? it's already out for the tranny fluid)
PTU fluid replace
And I'll eventually replace the RDU fluid as well
So, the installation of these entry/mid level coilovers.... I can't say how great the quality is yet as I haven't driven the car with them and I have no prior experience with coilovers, hence why it's taking so long. I think, overall they're good quality, but Godspeed needs to do a better job of checking their parts / packaging and providing some better instructions.
The first issue I had was with the Godspeed sway bar links that came with the kit. They simply wouldn't fit.
F23cb1f637af0378b3dcb31ff8f9c973
24b6f2bb2484d7ee45f6559331109a3f
The rod was too short to fit through the hole on the coilovers and bolt them on. So I bought a nice set of Maxpeedingrods, which came with extra center sections for more adjustability and have longer rods so I can securely bolt them on. They're technically for a BMW, but I read many comments and people use them for many different cars. It did take some time to get them adjusted properly where I can turn all the way left or right without them rubbing as they're thicker than stock.
57041330c63ca5b14f38c7466562165b
Now onto the rear divorced spring/coil. The old ones were much easier to take off and they went on much faster. The issue I had with these were that the factory top hat doesn't fit the threads of the shock.
A8baccd33799b661a95233ce5b22f9d1
768f1ec19462429739f4b8113b24ae10
According to Godspeed there should have been M12 1.25 nuts in the box that I didn't receive and I'm supposed to separate the rubber from the factory top hat and use that with a washer and nut. Luckily I had the Godspeed adjustable sway bar links that I can't use and the nuts are a direct fit. So, with the factory rubber top underneath the car, the factory rubber top hat inside the car, a large washer, and nut, it's well secured.
It took a little time / research to figure out how to adjust the divorced setup. Essentially I adjusted the plate on the spring to what I guessed would be the right height, jacked it up until it held firm, then adjusted the collar on the shock until it felt snug. Then I dropped my jack and lowered it back down until I could wiggle the shock by hand. I then adjusted the shock again until it no longer moved. Then I preloaded the shock by jacking it back up slightly, and adjusting the shock once more to that level.
I'll measure the adjustments I made and duplicate them on the other side. Then I can put the wheels on, drop the car, and see how I like the ride height. I haven't tightened any of the collars on any part of the coilovers yet. When I feel like I've made all of my final adjustments, then I'll snug them up (with a screwdriver / hammer as Godspeed recommends).
boookboy
