recieved rod bearings...now what?
Rio
West Bloomfield, Michigan
Hey guys...its me AGAIN
I recieved the rod bearings from NAPA just now. I am going to replace them today. I need all of the information. Where can I find step-by-step directions to this process. I know Scott did a write-up when he changed his recently. I found these two places...
Kurtmetros.com
krazgeo.com
Where else can I go to get some valuable information concerning this process...well...besids here. wink
BlackOnBlackATX
Dutchess County, NY
i know there are a bunch of write ups on here from good, experienced people. i would seriously heed all that you find on the forum. good luck and let us know how it all goes!
shojuan
sunny San Juan Bautista,
Start by getting the car up on jackstands (don't even think about getting under that car with just a floor jack supporting it!). Then drain the oil and remove the y-pipe and then unbolt the oil pan.
Rio
okay, I have the jackstands...
SHOooo, I read his write-up, it is really good. I mentioned that in my original post. Does anyone have any other sites that I should check out?
thanx guys
Place the jackstands on the subframe opposite the wheels. The day/night before start soaking the manifold studs with PB Blaster. You will need an impact wrench to get these off probably without breaking them, go just a little at a time in one direction then go back. Don't try to get the studs off in one try. Use plenty of the Blaster stuff. Works great.
Buy a tube of the black silicone for the oil pan. Get some new oil pan end gaskets too.
Rio
Okay...i searched...but where can I located the o2 sensor connections? I am currently under the car with a puzzled look on my face. Also, the Y-pipe is connected WAY up past the oil pan, how do I get to those bolts without taking off the front bar that is below it?!
Mr Anonymous
Tire Wall
Rio:
The O2 sensors are in the two sides of the y-pipe. Follow the wires to the connectors -- one is in front of the motor just above the starter (should be taped/tie-wrapped to the main battery wires), and the other is on top of the tranny, right by the two lines to the PS cooler.
Next you need to separate the Y-pipe from the catback at the ****** in front of the flex pipe. Then you'll need a set of long extensions to reach the nuts on the exh. manifolds. I like to use enough extensions so I can put a piece of pipe over the end of the ratchet to give me extra leverage. Once those nuts are off, then remove the bolts securing the y-pipe to the tranny case and VOILA!
Rio
I couldnt reach the O2 sensor in the back. It is F'n impossible. :mad:
I can see where it leads into the Y-pipe, but I cant see the connector. :eek:
Mr Anonymous
Tire Wall
Rio:
Go in from the top, You'll see the connector right next to the two lines leading to the PS cooler.
Rio
ok...
hey man, thanx for all the help, but getting this damn Y-pipe seems ****** imbossible. :( dont think the car is up high enough...I have very little room to work.
Bizzy
Rio:
ok...
Trust me, that's a very normal feeling. But if you're under it there is room enough to drop the pipe. It's just more difficult than if it were on a lift. How's the work coming? Keep us posted.
