Stock Location Turbo options: What we know now
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
I’m writing this from direct experience, not theory. I’ve owned, run, bought, sold, and walked away from multiple stock-location turbo options on this platform, and my opinions changed as results, data, and time accumulated.
I personally ran GH Gen3 turbos. I limited them to 19 psi and used nitrous and meth to make power, and they lived. Around the same time, a close friend of mine ran an 11.8 on stock turbos with supporting mods at New England Dragway on a Brew City Boost tune, on the same day I set the world record for the platform. That alone showed me that turbo upgrades are not always the limiting factor people think they are, especially when the overall combination is right.
When I started my engine build, I originally opted for GH Gen3R turbos. At the time, they were rumored to outflow ATP, but there was no data to support that. That kind of “trust me bro” messaging is common from this developer, and in my experience it rarely pans out long term. I sold my original Gen3 set, which were in great condition, and used that money to buy a lightly used set of Gen3R turbos from Jordan. One wheel had a small amount of FOD, meaning foreign object damage where a small piece of debris lightly contacted the wheel. I had them ported by Max Power Automotive, just like I did with my Gen3s.
As I got deeper into the build, I started getting uneasy about the actual ceiling of these turbos. I didn’t want to spend a large amount of money only to end up boxed in by their max power, especially knowing that max usually lives outside the efficiency range anyway. Around the same time, it became harder to ignore that many of the GH variants seemed overrated. A lot of people expected major gains and ended up with lackluster results relative to the hype.
There’s also a lot of false honor wrapped around full-weight dogma in these discussions. Running full weight is not easy, and getting into the 11s full weight is still a real accomplishment. But using full weight as a shield to explain underwhelming results doesn’t change the underlying performance limits. Physics doesn’t care about labels.
That’s when I decided to get out before going further down that road. I sold the Gen3R turbos to the same friend who had run 11.8 on stock turbos. He installed them and began tuning with GH. Despite the upgrade, he was never able to match that 11.8 pass again. That made it clear to me that I had avoided a major setback in my own build, and honestly, I was disappointed for him. The expectation was that upgraded turbos would move the needle forward, not backward.
Before getting into recommendations, one thing needs to be said clearly. A lot of turbos fail from overspeed caused by excessive drive pressure, not simply from too much boost and not because someone didn’t follow a turbo break-in procedure. When exhaust flow can’t support the requested boost, drive pressure climbs fast, shaft speed increases, and parts fail. That’s a flow and physics problem, not a driver problem.
CRP Engineering
This is who I would recommend right now for stock-location turbo upgrades. Their turbos are being used in real high-level builds, including the world’s fastest Explorer ST. That matters more to me than claims or screenshots. Results like that require correct compressor and turbine matching and enough flow to keep drive pressure under control. From what I’ve seen, CRP approaches this from an engineering standpoint, not just bigger wheels and hope.
GearHead Tuning
I previously ran GH turbos and understand why people are drawn to them, especially when they were priced around $1,900. At that price point, the decision made sense. With pricing now near parity with other options, that value advantage is gone. Combined with years of real-world outcomes that haven’t consistently matched early expectations, GH is no longer who I would point someone toward today. This isn’t about personalities or loyalty. It’s about what the last several years have actually shown.
Turbo Bay Performance
Turbo Bay has offered stock-location options as well, but I’ve seen mixed experiences. One case involved issues on a built motor, with part of the explanation being a required turbo break-in procedure. Turbos don’t have wear surfaces that need break-in like engines do. They live or die by oiling, balance, boost control, and drive pressure. When problems get explained primarily through break-in language, that lowers my confidence.
ATP
ATP previously offered stock-location turbo options for this platform, but they are discontinued. They’re worth mentioning for history, not as a current option.
I’m not personally shopping for stock-location turbos. This is written for people who may not realize that the turbo upgrade landscape for this platform has matured. GearHead has now been around for the better part of six years, which means we’re no longer judging based on early hype or first adopters. We’ve had enough time to see patterns, limits, and repeat outcomes across many cars and many tuners.
For anyone who hasn’t revisited turbo options in a while and assumes the old recommendations still apply, this is simply an updated perspective based on what we know now. Based on pricing, accumulated real-world results, and a clearer understanding of what actually limits or kills turbos, CRP Engineering is the option I’m comfortable pointing people toward today.
That doesn’t mean everyone needs new turbos, and it doesn’t mean older options were useless. It just means the information has evolved, and recommendations should evolve with it.
mattr66usa
Texas
CRP Engineering
GearHead Tuning
ATP
Why are you recommending someone's turbos based off successes on a completely different platform? The important thing is are the turbo builders maximizing the turbine flow as much as possible (and turbine wheels are the only current option on the SHO). How is this being addressed with engineering if we are all being limited to the stock turbine housing? I for one would love to see some larger turbine housings. Gearhead turbos are based off completely new turbos and don't have cores now, hence the price increase. There is a reason gearhead is on the gen3. The gen3 was the 3rd iteration of turbine and compressor combinations that provided the best compromise of 500whp on E30 while keeping stock-like spoolup. The goal was never more than 500whp since that is where the stock trans likes to start giving issues. We built very few 3r setups, but the 3r had an even larger turbine wheel than the gen 3 and a larger compressor (as big as we were comfortable putting in a stock housing). That's why you didn't overspeed the 3r with nitrous. The turbine ate it no problem. Now that we have transmission builds, we can start looking past that and go for bigger power. Good luck with your build.
Majestic
Strange obsession with Matt, Andrew. Get some professional help, both with your head and your build. Looks like you need a lot of help with both.
CraxyMitch
Ohio
What am I missing here? 802 made a post about all turbos, and his experiences and opinions, then Matt defended his stuff (of course, he should). Then Majestic jumps in and insults 802? What's the reason? Massive fanboy crush?
I appreciate people sharing experience, details, opinions, and specifications for my own enrichment, even when I don't necessarily agree... And I'll probably still upgrade to GH. But why the rank animosity, Majestic?
mattr66usa
Texas
It must be because 802 has chosen to mount multiple attacks on me on multiple forums and Facebook pages that has caused me to have to dedicate resources (that I should be using to serve actual customers) to defend myself. This all stems from me telling him that I am missing the parameters I need to tune his car properly instead of telling him I can do it without those items, which would be disingenuous. I'm being attacked for being honest, but that bridge is so burned now that I don't think there is any going back. He should be focusing on his build and proving me wrong at this point because he has dug himself in such a deep hole (totally his doing), he either needs to go ahead and remove all his AI musings and attacks or show us all how wrong I am with actual proof.
Since I started tuning the EcoBoost platform, I have tried my best to be honest with everyone about everything and not just try and promote a brand. This attack on my brand has taken a turn and is obviously now personal for 802 and not based on any reality. He made a post on this site about turbines limiting overall power production but recommends a turbo to people that does nothing to address the turbine side deficiency of the SHO turbos.
802SHO
Great question. He appears to have read me 100% wrong from older discussions. I’d definitely encourage you to go with whatever choice makes the most sense to you. It wouldn’t hurt to browse both CRP Engineering and GHTuning. Either or will work. Whichever way you go make sure you have enough supporting mods and your tuner aims upwards of 18 psi (at least) or it’s really not worth the upgrade imo.
CRP Engineering is the strongest option in my opinion, as I stated bc the pricing is so comparable now. They make a bunch of hybrid turbos for multiple platforms. They can also do cool custom stuff. They can make you custom exhaust manifolds now. Between the companies they really stand alone. It’s all up to you, of course.
Just remember, you’ll hit a dangerous level of EMP:Boost ratio with hybrids, often more dangerous than stock due to higher drive pressure for a given boost level.
I don’t think it’s wise to push hybrids past 20 psi on a stock motor. But then it’s also not worth a motor build just to survive the extreme EMP pressures that 21-24psi boost Hybrids will choke at anyway. Stock motor with hybrids at 19 psi proved reliable for me.
However any of this info is useful or not is at your discretion. You can decide for yourself
Majestic
Read more.
mattr66usa
Texas
Again, you are pushing CRP that we now know does nothing about the very drive pressure issue that you are saying is a problem. The Gen 3 Gearhead actually have a 5mm larger turbine to address this. Past this point, the turbine housing is the restriction (that nobody has addressed to this point because of cost).
Texas Marauder
Lone Star State
Delete is next to edit. Possibly because you are a new member. If that's the reason my question is answered.
1768860669576
hosbaldosho
