Storm-Chaser
Well, edit it so it's not so "apparent" and doesn't get deleted . . . .
You might want to ask Jason what he did to adapt the Mocal sandwich adapter extension sleeve to the block, as the block thread is M20-something straight thread, and the original oil cooler stem changes this to 3/4" -16 thread for a standard FL-1A style filter. If you have to go all M20, then all it does is change the thread of the filter you buy from Canton. You may have to source an M20 straight thread pipe ******. BAT may have something, be sure to ask.
not trying to be rude on this but any oil filter that cost $104 isnt a solution id personally use.
could their be another solution ?
Not one that's guaranteed to have the flow-vs-pressure drop characteristics that Ernie needs to keep his engine alive. If a $104 oil filter keeps a $4000 race engine running, is it worth it?not trying to be rude on this but any oil filter that cost $104 isnt a solution id personally use.
John,In addition to some of the great pointers you've received, I would find the article from a few years ago (early 2000's) published in the SCCA rag on how to make journal bearings live at high rpm. They used as an example a 3 inch stroke engine IIRC, pretty close to our 80 mm stroke (yours might be a tad lower). The key issue is that the oil in the crank throw gets accelerated by centrifugal forces at high rpm faster than the pump can supply it. zak
I don't have a pic with the large hoses, but here is the sandwhich and cooler.
One other thought, I assume you are using one of the Ishkagawa (sp?) crank scrapers (carefully clearanced to your crank), and that you've knife edged and polished the crank to help it slice through the oil and reduce its aeration.
Is the #3 main the one that feeds #5 cylinder? Sorry, I just haven't got in to the oil routes in the motor yet.
Ernie.
