rod journal size
79svt
Northern Al.
I have a 3.0 and I spun a bearing on no 5 rod can anyone tell me what the rod journal size is?????
Off Road SHO
Moderator
It will say the size on the non rubbing side of the rest of the bearings; either STD (standard), or .25, .50, .75mm. These numbers are the amount the crank has been turned down from a prior problem. If the crank hasn't been turned down before, it will have STD bearings.
Please don't think that you can put an oversize bearing in place of the spun bearing. It doesn't work that way, the spinning doesn't take much off the crank journal, it just puts some nice grooves in it.
Tom
thatSHOguy101
