Crank timing gear bolt size for puller?
14TR
Pennsylvania
Hey guys, anyone know for sure the size of the two small threaded holes on the crank timing belt gear? The ones you would use to mount the puller to it to remove the timing gear from the crank nose?
Second question, I know bearings etc are bordering on unobtainium, but what about piston rings for 3.0 and 3.2’s?
tracy_s_1993_atx
Plano, Texas
I believe that the thread in the timing gear on the crankshaft is the same as the bolts that hold the plastic cover for the timing belt.
Michael
14TR
Pennsylvania
You are correct! That’s exactly the size it turned out to be thank you. Anyone else looking for the info it’s M6 1.0, you need about 2.5-3” screws for the puller in that size
Brumfield780
