1st time caller, long time lurker
2017SHO
Colorado
Hello- i own a 2017 black, stock. Got it in 2019 with 12kmi and it's been fun road-trip car now with 100kmi. Well maintained from helpful advice found on this site - oil, trans, RPU, etc.
Last week the 3.5 started the dreaded coolant leak out of engine block weep hole indicating internal h2o pump needs replacement. Car also has cam phaser rattle on cold start. Joined forum to better search post archives for advice, preferred parts, tools, etc. Seems like deleting the internal pump for external electrical pump should be possible with appropriate block off plate with idler gear for timing chain. $4k repair estimate here - colorado
Back to searching! Thanks
kryptto
South East, Florida
Welcome - i dont yet have any experiences with those replacement - this is the place to be for sure.
2017SHO
Colorado
Looking for the torque sequence for the intake manifold. With search i saw 10 Nm + 45 deg for torque, but could not find the torque sequence. thx!
kryptto
South East, Florida
Stage 1: Tighten to .................... 10 Nm (89 lb-in).
Stage 2: Tighten an additional .................... 45 degrees
  • Mechanical (including Torque) (Intake Manifold) - ALLDATA diy.PDF
2017SHO
Colorado
Thank You! would not have guessed that sequence. Is the T-stat housing/elbow the same torque - 10 Nm then 45 deg?
hosbaldosho
