SM105K's SHO BIBLE/BUILDS/LIFE
First things first. Thank you @SHOdded for helping me with the information below. His knowledge and experience with this platform is immense.
What to expect:
Post one: General knowledge of the SHO and what to expect.
Post two: The Story of M, my SHO. I posted all of my mods, current mods, and issues. I also have added the links, pics, and videos of my build within this build thread kinda like cliffnotes. My ownership of "M" ended 6/7/2024
Post three:
Goals for "M". Power and Track Goals. I achieved some, and didn't achieve others.
So you bought an SHO? Good, welcome to the club. First things first. This is a performance vehicle regardless of the Taurus badges. It is twin turbo, and all wheel drive. That being said, there are more maintenance costs and more opportunities to spend money the wrong way with your SHO.
So do you have the original window sticker? Do you know if your car is a PP car or Non-PP car? You ask what is a PP? It relates to the Performance Package that some SHO's came factory with. An easy way to figure out if you have a PP equipped car is look at the window sticker. Below is my factory sticker. As you can see under optional equipment, there is a "SHO PERF PKG w/ALCANT WHL. So I had a PP. But what if I don't have a sticker? Don't fret I got you.
Window sticker
First look for the 20 inch "flower" wheels. Most PP cars came with them. Look for the alcantara wrapped steering wheel, and pop the trunk and look for a spare tire. If you see a no spare tire, you most likely have a PP car. There are numerous other things like TC button, 3.16 final drive ratio, PTU cooler, trans cooler, upgraded pistons, better brake pads ect. Check the brochure below.
Ppsho
The newest SHO's (2019) are considered old, I would highly recommend changing all the fluids. That would include the engine oil, the coolant, power transfer unit fluid, rear diff fluid, and I would start cycling trans fluid.
In post 9 and 10 of that thread, I break down a moderate fluid maintenance program vs an extreme use program. Use that info to make an educated decision.
ENGINE OIL! Read the article below. It is one of the most important things you can read and be proactive with your car.
https://www.motor.com/magazine-summary/resolving-low-speed-pre-ignition/
Change your oil with a quality oil and has been tested and formulated for Turbo Gasoline Direct Injected engines. Also do not skimp on your oil change frequency either. I personally change mine every 3k miles. It's super cheap and I used an extreme maintenance protocol with my SHO. Most will say every 5k miles. I agree but would not exceed 5k miles.
Next up is coolant. Coolant is very important with the 3.5 Ecoboost engine. Not only does it help regulate temp, it also acting as a lubricate for the water pump. It conditions the seals, and allows coolant to stay out of bearings within the water pump. The 3.5 EB engine has an internal water pump (underneath the timing cover). Though these pumps don't often fail, when they do it is catastrophic for the engine. However there are signs if the water pump is failing. It will start weeping coolant so start paying attention.
I would change my coolant every 30k miles miles too. In a "normal" climate say the Midwest Ford recommends a 50/50 coolant to distilled water mix. In the Great North where it gets extremely cold Ford recommends a 60/40 coolant to distilled water mix. In the Southwest (I am from Phoenix) where it can get extremely hot, I run what Ford recommends at 40/60 coolant to distilled water mix.
PTU! Understanding why it fails and ways to prevent failure. If you smell a propane/rotten eggs smell from your car it is most likely the PTU. Also if your PTU is making noise.....it is cooked. Please read below.
Yes that thing. Here is a very good explanation by a member on here named Mr.HighCaliber.
"PTU's don't fail at least not from a power handling perspective. These only fail from lack of maintenance. Spun bearings and galling of the gears from lack of lubrication.
High Heat dries up the lighter oil molecules in the ****, which causes more heat due to lack of lubrication (thermal runaway) which leads to the remaining gear oil turning to thick black paste which clogs up the vent tube in the ptu which cause pressure buildup in the ptu which forces the remaining, non-congealed fluid out past the shaft seals. Now the only left is a thick paste thats easily flung off of the gears, sticking only to the case. After this chain of events, the bearings run dry and begin to fail, next are the gears. Tolerances widen or things begin to sieze. Bearing and gear noise are usually the first signs of mechanical failure.
But the PTU internals are stout. The weakest part of our powertrain is the RDU Atc coupler. (The electronic coupler in the rear differential). At least in terms of tq capacity and power handling."
The being said, you will need to change your PTU fluid.
FordTechMakuloco shows you the jist of the procedure here.
If you have a 2010-2012 and 13 + non PP you will need a Mighty Vac device to suck out the PTU Fluid. Refill directions are the same as below.
If you have a 2013+ PP this is the easiest way to change the fluid.
What I did, what I used, and how I did it. You can do it yourself, or you can have a shop do this.
I would buy some Redline Lightweight Shockproof fluid off Amazon, 2 and a half feet of 1/4 id rubber fuel hose, some aluminum foil, and this thread to them below.
https://www.ecoboostperformanceforum.com/index.php/topic,8081.msg144207.html#msg144207
I would bring aluminum foil to cover the downpipes and 02 sensor. Drain the PTU fluid and have them catch the fluid in a pan. Measure to see how much comes out, and the how bad shape the fluid is in. See if there are any chunkies in the fluid. Metal shavings on the magnet drain plug are normal. The aluminum foil will protect everything and clean up will be a snap. Clean and re-install the drain plug.
Route the hose down from near the brake booster. Then tell them to remove vent hose and check valve from the top of the PTU and slip that 1/4 inch fuel line hose onto the vent tube. The hose will be snug and should not slip off. Use that to fill refill the PTU with fluid. This will take some time. The PTU holds roughly 18 oz of fluid. Put the check valve on the top of the hose and place it near the brake booster for next time. It's that simple.
RDU: Here is a thread all about replacing the RDU Fluid.
https://www.ecoboostperformanceforum.com/index.php?topic=1708.0
Trans:
You will hear us refer to trans fluid cycling.
Again FordTechMakuLoco again shows you the jist of the procedure.
This is the 5 quart out and 5 quart in method. Use Mercon LV. The 6f55 transmission in our SHO's like clean fluid. The trans is a sealed unit so you cannot service the filter. So to keep the fluid clean, I trans fluid cycle. I do it every oil change. I am under the car, and trans fluid is dirt cheap. Pull the trans plug and roughly 5 quarts will come out. Measure and add back the 5 quarts of new Mercon LV fluid. If you do this 5 times, you will have roughly 90 percent newer fluid. Then swap every other oil change.
TUNE: After you have done all of this....then I would start modifying and tuning your SHO. Below is a quick summary of how this is done.
Do your diligence when selecting a tuner/tune for your SHO. I recommend AJPTurbo (Brad) and Gearhead (Matt) however there are great tuners out there as well. STAY AWAY FROM LMS (Livernois) if you have 13+ SHO and STAY AWAY FROM SSI. tuning company for the Ecoboost SHO.
If you are running a 3 bar map sensor tune, install the map sensor first. Follow the directions from your tuner. You will need to plug in the device and find your vehicle strategy number. You will send that to your tuner. They will then send you the tune. Upload the tune onto your device (your device will come with instructions on how to do this). Take your device to your vehicle plug it in and turn on your accessory power. Personally I would drop all of your windows at the time. The device will power up. Go to the "program vehicle" menu. Select whatever tune the your tuner sent you. Click configure/program vehicle. DO NOT OPEN ANY DOOR UNTIL YOUR DEVICES SAYS PROGRAM COMPLETE! IF YOU DO, IT MAY BRICK THE SYSTEM. If it is the first time loading a tune into your vehicle, it will download your stock tune to the device. This can be reinstalled later if you need it. Continue following the prompts. You will have to turn the ignition off and on (DO NOT START THE ENGINE) during this process, relax and follow the prompts. Loading the tune should last 7 to 10 mins. After your device says "program complete", you can start the vehicle. Your vehicle is now tuned. Depending on tuner you may have to data log. Follow your tuner's directions on that as well.
Did you purchase a Gearhead Intercooler? The install video is below.
I would also consider boost leak testing your car. Here is a video describing how to the process is done.
Things to check out are charge piping. This includes the blow off valves (BOV). They have a diaphragm that can be compromised and leak boost. They are simple to check. One electric plug and two bolts. This may actually be your first mod, if you like the whoosh that BOV make when they vent to atmosphere. Below is what you will need to complete this mod.
xFallenxCripplex
What creates those spikes on the Dyno graph?
Sent from my Pixel 2 XL using Tapatalk
My ownership of this SHO ended 6/7/2024. Below is my time line with her.
This is the story of my SHO. I call her "M". I liken her to Judi Dench's character "M" in the James Bond franchise. Plus the first owner was a older aged (65) woman who in my mind from the stories I heard about her is a bad lady. She traded my SHO in on a 2018 Shelby 350 GT at age 70! Like I said, she is a bad lady.
I go into depth about the mods that I have done, plan to do, along with the failures and triumphs I have had with "M". I talk about dyno sessions, track sessions, different fuels, different tunes pertaining to different fuels, and chasing that elusive 400 all wheel horsepower mark and 11 second quarter mile time slip. Enjoy.
I bought my 2013 PP SHO in May of 2018 with 51K on her. Car was completely stock.
I took purchase and immediately started modifying the car. This is everything so far.
Exterior: Limo Tint, Wind Screen Tint Banner, Rear End Leveled (Yes I cut the stock PP springs) Installed H&R Springs (I later cut the rear H&R Springs), Full Paint Correction, Car Pro Ceramic Coat, Car Pro Gliss Top Coat, Trunk De-badged, Devires Custom Burnt Copper Color "Turbo Bull" Stickers Over Ford Emblems, Color Matched All Chrome Trim Pieces, Tail Lights Professionally Painted/Tinted, Custom Mesh Grill (Ford Emblem Removed), AVS Flush Mount Deflector.
Before and Completely Stock:
Bone Stock
Next was dark tint, paint correction, ceramic coating, and leveled rear:
20180723 083246
Next was H&R springs:
HRs
As she sits now. Curva Concept C7's, Chrome Delete, Trim Paint Match, Smoked Tail Lights, AVS Flush Deflector, Custom Grill, sitting on cut rear H&R's.
20200308 112635
20200308 112853
20200308 112832
20200308 112706
20200815 104728
20190629 154826
Maintenance:
PTU fluid was changed at 60K miles I went with Mobil One Gear Oil. This was replaced at 68K miles with Redline Light Weight Shockproof Fluid. RDU Fluid was replaced at 69K miles with Redline Light Weight Shock Proof Fluid. Brake Fluid Flush (mine was red). Coolant and new T-Stat replaced at 69.5K miles. I change my oil every 3K miles religiously with Castrol Edge (buy it at Walmart, it is dirt cheap). O2's sensors changed at 69.5K miles.
Misc Mods: Forscan hacked the Navigation System (turned it on), Added the Intelligent AWD Gauge.
Current Performance Configuration: AJPTurbo E30 Tune on a LiveWire TS, 411 HP and 546 TQ, FS HPFP, DIY IC sprayer, PPE Catted Down Pipes, 3rd Cat and Stock Resonator Delete, Custom Mid Pipes with Magnaflow Resonator, Dicunzolo Gen 2 Trans Mounts, Derale Upgraded Trans Cooler, MSD Coils, SP- 542 Plugs, K&N Drop In (stock air box), Vented BOV's, H&R Springs, Powerstop Drilled and Slotted Rotors with OEM stock PP pads, Curva Concept C7's wrapped in Continental DWS06 Extreme Contact Rubber.
Post 1005: All of my mods, and how they affected my SHO summary :
Mods On Deck: None at this time.
Post 2135: Powerstop Brake Install and Red Fluid.....:
https://shoforum.com/index.php?thre...o-your-sho-today.130526/page-107#post-1499353
Post 93: Gearhead Intercooler Install:
https://shoforum.com/index.php?thre...-performance-maintenance-thread.138235/page-5
Post 101: Tricks I used for the GH Intercooler install:
https://shoforum.com/index.php?thre...-performance-maintenance-thread.138235/page-6
Post 121: H&R spring install and insights:
https://shoforum.com/index.php?thre...-performance-maintenance-thread.138235/page-7
Post 177: The street light grand prix is open for business:
https://shoforum.com/index.php?thre...-performance-maintenance-thread.138235/page-9
Post 277: ALL CHROME TRIM MUST DIE!:
https://shoforum.com/index.php?thre...performance-maintenance-thread.138235/page-14
Post 283 & 284: Paint correction and Curvas installed. Post 296 paint matched trim goes on along with the AD Gen 2 TQ Mounts:
https://shoforum.com/index.php?thre...performance-maintenance-thread.138235/page-15
Post 291: Technical Data on my Curva C7's:
Post 322: PPE catted DP's install on with Heat Wrap:
https://shoforum.com/index.php?thre...performance-maintenance-thread.138235/page-17
Post 369: 3rd Cat and stock resonator delete. Custom Mid Pipes and Magnaflow Resonator installed along with videos:
https://shoforum.com/index.php?thre...performance-maintenance-thread.138235/page-19
Post 395: MSD coil and new spark plug install:
https://shoforum.com/index.php?thre...performance-maintenance-thread.138235/page-20
Post 441: Custom Painted Tail Light before and after:
https://shoforum.com/index.php?thre...performance-maintenance-thread.138235/page-23
Post 452: Progressive pics of the various ride heights of my SHO. From stock to cut H&R Springs:
Post 466: Pics of the custom grill install:
https://shoforum.com/index.php?thre...performance-maintenance-thread.138235/page-24
Post 542: EPP Noise Maker Delete install and under air Dam GH IC drain access hole mod:
https://shoforum.com/index.php?thre...performance-maintenance-thread.138235/page-28
Post 576 and 579: Clean/Prep and Ceramic Coating of my Curva Concepts C7s:
https://shoforum.com/index.php?thre...aintenance-thread.138235/page-29#post-1538596
Post 606 for Derale Trans Cooler Install:
https://shoforum.com/index.php?thre...performance-maintenance-thread.138235/page-31
Post 698 802SHO Custom Splitter and Duraflex Chin Spoiler Install:
https://shoforum.com/index.php?thre...performance-maintenance-thread.138235/page-35
Post 776 DIY Intercooler Sprayer:
https://shoforum.com/index.php?thre...performance-maintenance-thread.138235/page-39
Post 863 is the data from the DIY Intercooler Sprayer:
Below is my documented 6F55 transmission failure at 68K miles.
Post 41: How my trans failed.
https://shoforum.com/index.php?thre...-performance-maintenance-thread.138235/page-3
Trans Failure Update: After inspection, the snap ring on the 3-5-R drum decided to exit stage left. It failed and wiped out the trans. The good thing is there was not a wave disc failure.
Post 60: Findings of trans failure.
New Trans Update: New trans is in the car. $4887.13 out the door with a 3 year/unlimited mileage warranty from Ford. Also, the trans shop was nice enough to change out the PTU and RDU fluids with Redline Lightweight Shockproof Fluid at 68,900 miles.
Post 67: Trans replacement.
https://shoforum.com/index.php?thre...-performance-maintenance-thread.138235/page-4
Post 7,714: Water Pump Starts to Weep.
Future Fluid Maintenance:
At 70K miles I starting following this schedule until the car left under new ownership.
Oil and Trans Fluids will be changed at the same time, along with the PTU and RDU.
Oil: every 3k miles (Castrol Edge with either a Motorcraft or Mobil 1 filter)
Trans Fluid: every 9k miles 5 quarts out, 5 new quarts in. (Mercon LV)
Brake Fluid: every 10K miles. Changed at 69K
PTU Fluid: every 10k miles (Redline Lightweight Shockproof Fluid) Changed at 112K.
RDU Fluid: every 40k miles (Redline Lightweight Shockproof Fluid) Changed at 69K
Coolant: Every Year. 50/50 mix. Changed at 98K
Batteries:
My SHO kills batteries every two years like clockwork. I replaced the battery that came with it 9/19, then 10/21 and now 8/23. Yes they are AGM.
This may seem extreme. however it is not really expensive. I buy my oil and filter from Walmart. Castrol Edge is good and less than $40 bucks with a Motorcraft filter. A case of Mercon LV is pretty cheap on Amazon. Redline is cheap (21 bucks on Amazon for quart bottles).
Starting on Page 47, I started to document my big turbo 2002 Lexus IS300 ownership.
On Page 67 I started to document my 2019 Mercedes E63S ownership.
On page 76 I started to document my 2000 Ford F450 ownership.
My comparison of the SHO vs The E63S below.
limited02
Olathe, KS
I believe Brad has made a touch over 400hp on his on SHO that he had, so I'd say it's doable for you in the right conditions. Without a doubt though, you'll get a 12.7 as you sit because that DA is a real killer!
On to the GOALS tune only!
I have a couple of goals I want to hit tune only. Tune only meaning stock intake and full stock exhaust, (K&N Drop In, Plugs, and AJPTurbo E30 tune)
Goal #1: I want to break into the 12's full weight with a quarter tank of gas. I went 13.082 at 109.42. Sixty foot was a terrible 1.98. Temp was 92 degrees, and the DA was 4002.2 feet. My IAT's were in the 170's so it was hot. First time at the track, so trying to get her to launch in boost without pushing was a struggle for me. I will figure that it out, that was on me. Once the temp comes down, and we can getting the timing that is being pulled back, I realistically see a 12.7/12.8? What do you think? Goal: 12.7/12.8 @ 110 (tune only)
9818 SHO
Goal Update: She went 12.85 at 105.47 in 3700 feet D.A. in 96 degree heat.
92218 WHP Timeslips
Goal Update: Track was trash, numerous oil downs. D.A. was 2900 feet and the temp was 78 degrees. Ending up running a 12.61 @109.23. Best MPH was 111.78 with a 12.66.
Still warm with crap D.A. Still not leaving like I want it too. Once it gets "cold here" I will try again.
1027WHP
Goal Update: Back to the track. Track was good, 58 degrees, 1200 D.A, Ended up running a 12.56 @108.98. With the new brakes, I was able to leave on 1 PSI of boost and she 60 footed 1.777! I did have an issue with a boost reference hose that was creating a boost leak.
111718 SHO
Goal #2:
I want to see if I can crack 400 awhp (tune only maybe if I have to use C20). I went to the dyno and in 105 degree heat with IAT's in the 170's again she cranked out 366 hp and 414 tq to the tires. Brad has even said, he has never see air temps that high in any other tune he was written. So in 60 degree air, timing that is being pulled, and maybe more boost (if Brad says its okay) do you think 400awhp is attainable?
I WAS NOT ABLE TO OBTAIN THIS GOAL TUNE ONLY.
First Dyno Session: 366 HP and 414 TQ 105 degree heat on pump 91 tune.
SHO Dyno Summer
Update: 391 HP and 470 TQ on 91 octane with Torco T85 E30 mix in 90 degree heat. Just came up short. I am extremely happy with the results. Once again when it gets cooler I will strap her to the dyno and crack that 4oo AHWP tune only mark.
SHO Dyno Fall 2018
Since my SHO is starting down the road of bolt ons I want to adjust the goals.
Update: 388 HP and 463 TQ with the new Gearhead Intercooler. I made the same HP with 2 psi less boost. Seems my turbos are worn out, and it is showing. It is struggling to keep up at Redline. Made the same power, but with less boost.
21519 SHO Dyno
Update: 391 HP and 494 TQ numbers after AJPTurbo E30 tune on stock HPFP, Gearhead Intercooler, PPE Catted Downpipes, Custom Magnaflow Resonator.
20191025 171224
Update: 411 HP and 546 TQ. AJP Turbo E30 Tune, FS HPFP, Stock IC, PPE Catted Downpipes, Custom Magnaflow Resonator, MSD Coils, K&N drop in.
Screenshot 20220131 095936 Gmail
New Bolt On Goals
Bolt On Track Goal #1: I want to run in the 11's at full weight with a quarter tank of fuel at all times. That means zero weight reduction! My car has already cut a 1.77 sixty foot tune only! Current mods hopefully gets me close.
Bolt On Power Goal #2: I want to crack 400 awhp and 530 tq with my current mods. Achieved : 411 hp and 546 tq.
Jeff2017
Goal #2: I want to see if I can crack 400 awhp (tune only maybe if I have to use C20). I went to the dyno and in 105 degree heat with IAT's in the 170's again she cranked out 366 hp and 414 tq to the tires. Brad has even said, he has never see air temps that high in any other tune he was written. So in 60 degree air, timing that is being pulled, and maybe more boost (if Brad says its okay) do you think 400awhp is attainable? Goal: 400 AWHP (tune only)
Just food for thought.
Well, John Blue on youtube has tuned his 2017 to 389HP and 480ftlb @ wheels with a livernois 93 octane tune, 3 bar, thermostat, plugs, catless DP's, Livernois exhaust and cold air intake. So it is doable but the exhaust side needs to be opened up. TQ is what you want anyway. HP is just for top speed and you cannot use that anyway unless you want to go to jail.
I talk to John, I have been watching his channel since day one. I wish my TQ was up, but heat, hight IAT's (which pull timing), and terrible DA are factors to track times and dyno pulls. I am going to take a run at 400 awhp with a tune only. Cooler air, more timing, more boost, might not get me there...but it will get me closer.
I might head to the track on Saturday. I will check the DA a couple of hours before, and if it is in the low 3000 I will hop in the car and let her eat.
Went to the track, got to her to leave better than before. 93 degrees 3900 DA. Maybe I will run a bracket race league? Could only get her to leave at around 2 psi of boost at the track before she started pushing. On the street she gets it with almost 5 psi on the launch...so I will start tinkering. Number: 122
Check one off the box. Excited to see what she does when it gets colder. I expect a 12.50 now.
limited02
Olathe, KS
Awesome!!! I'd say 12.5's are doable after a pass like that in those conditions.
JohnBlueGT
Ohio
I am trying for 400 whp on mine as well, but just shy of it. Not sure if I want to push for that last 10 hp though lol
stevelaw_2000
John, what do you have to get to 390?
Did I see that you have down pipes, plugs, 3 bar, tstat and tune? What fuel are you using?
JohnBlueGT
Ohio
That mod list is pretty accurate for what I have. Full exhaust system and intake as well. I run 93 octane currently.
stevelaw_2000
Have you been on a dyno to get those numbers, I'm in Arkansas and I'm told there isn't an awd dyno in the entire state. What do you think of the new aFE? Intake that claims to make extra hp in our cars?
I updated the goals. Hopefully tomorrow we should see some cool stuff.
boookboy
Staff online
