What the **** is going on with this car???
I bought it in august and the water pump went out in three days (1000 miles, had to drive it from chicago to DC). So I did the 60k on the lower end. I wanted to build this car up and already have new calipers and rotors all the way around with 96 upgrade on front. But every week there is some new problem. First I noticed the loud knock on start up, I thought rod bearings might be the cause. I noticed a significant coolant leak, looks like it's coming from between the radiator and plastic tank on the side of it somewhere, shoshop recommends new radiator (how unreliable is the reclamp procedure?). Today the oil light came on and I just changed the damn oil 500 miles ago with Castrol GTX 10w-30 (As advised by SHO einstein sdpatt). Not to mention the coolant light was already on because it's hard to keep up with. Oh yea AND the freaking door ajar light is on which I'm not too concerned about but when you have three lights blasting you from the dash things don't look good man. Jesus, something else I remembered, the last few days when rolling very slow there is a sound like pushing furniture across a wood floor, it's coming from the front and I assume it's wheel bearings. What do I do about this? I'm thinking about not putting any more money in this engine and going with a 3.2 conversion. Ideas? Thoughts? Advice? Complaints about a really long post?
