I guess when all the engines fail and we can't get bearings, we all buy Gen 3s, and build the motors up.
I remember the days when you could get a set for a like $35.
I just bought mine from RCM at 50 shipped.
I've got one set stashed.
When that is gone I quit also.
Just checked... Napa 4 blocks away has bearings for my SHO.![]()
Would there be interest in rod bearings that would provide a tighter clearance than the 0.002 typically achieved with the Clevites? Botton of the spec is 0.0009 IIRC. These would be more expensive than the Clevites thus I never follow up on them.
A tighter clearance helps the engine maintain oil pressure more readily at high rpm. An analysis of an engine with a similar stroke to the SHOs was made in an article in SportsCar about a decade ago, and the forces that act on the oil in the holes feeding the bearings are quite large. They noted the criticality of maintaining tight bearing to jounral clearnaces on high rpm engines due to this effect (and may explain the SHOs propensity for spinning rod bearings).
If there is interest I'll try them out on my 3.2 build this winter.
napa has the wrong parts listed in their computer system - the 3.0 vulcan bearings come up as the bearing for the sho, so make sure you get the ones you need.
Mahle Clevite Customer Service phone number: (800) 223 9152
They have 300 on order to be available in late October or early November.
:thankyou: :thankyou: :thankyou:I guess I dont really see our rod bearings as that much of a weak point compared to other engines. I just see it as an items that recieves more stress because our engines were to see high rpms (for a v6 in 1989). With good oils changes my bearings still looked okay at 160K miles of not so nice driving. .
@HamalT Don't worry we won't make the SHO guys sad...It will be back in stock in November.
