13:1 Compression 3.3L cam'n its ass off
zach44102
BIG TURBO
Georgia
20140322 193746 zps2nymxnbu20140322 170058 zpswxijbwze
20140322 204039 zpscf8iiw1x
small update, SHOsource steel billet 17lb flywheel, ARP Flywheel bolts, ARP pressure plate bolts, and Intake manifold gasket set.
spent some time.assembling the coolant lines/thermostat housing/coolant crossover tube. Also got the coil pack on.
Next week the motor gets a wiring harness, fuel rails, a set of ID1000's. And i will probably start on the intake manifold.
SHOCH
Tommy Boy
near SHOcago
Looking great! So happy the "Drift King" is dead. Also with weight reduction you could go the Penske 1967 Camaro Trans Am route and have your panels dipped in acid to thin up the metal. Hope to hear it running in Texas.
zach44102
BIG TURBO
Georgia
Fuel System SUNDAY!
255lph fuel pump, ID1000 injectors, polished up the fuel rails. Got the engine wiring harness on and did the belts. The belts may change if i can find a better way to route the ALT belt.
ignore the ****** polish job.
20140330 144352 zps0pjmz3qg
20140330 144414 zpsmydhilsz
20140330 145954 zpsa91l8elo
20140330 150001 zpsnhoxgzct
20140330 171303 zpslplqd2jl
Sholovenothate
4 SHO's
Southern USA
just curious, what got you to go with Purple? sports team etc? Everything looks damn clean man!! going to be nice to fire it up that first time ;)
what exhaust you going with?
yamahaSHO
E85 whore
Arkansas
If you had bored fuel rails, you could have run the 14mm top hats... Which are purple. :p
zach44102
BIG TURBO
Georgia
When I first got the injectors I was so disappointed that they were not purple.
I went with purple cause its FABULOUS DUH!!!
jayro
Auburn, In
20140330 171303 zpslplqd2jl[/URL]
I routed my ALT belt on the other side of the tensioner and pushed down on the belt to take up the slack. It gave me more belt wrap around the ALT/crank pulley's and got good tension prior to getting too close to the other side of the belt loop.
zach44102
BIG TURBO
Georgia
I am going to change that this weekend. After looking at the pics I came to the same conclusion.
zach44102
BIG TURBO
Georgia
WE ARE IN THE HOME STRETCH!
NEXT WEEKEND HOPEFULLY THE ENGINE GOES IN.
AFTER SITTING FOR 2 YEARS IT WAS TIME TO CLEAN IT UP AND CHANGE THINGS UP.
20140405 154444 zpso0xrypfx
20140405 154448 zps4wvvvwkh
20140405 171128 zpso29mgcb7
20140405 175128 zpsfd2qlztc
20140405 195149 zpskys65mnx
20140405 195155 zpsuftmwcdq
20140405 195201 zps7ynsvywt
Too bad all this work will be hidden when the engine gets popped in there!
zach44102
BIG TURBO
Georgia
IN THE HOME STRETCH. MOTOR IS GOING TO BE STARTED THIS WEEK. 12 SECOND ALL MOTOR SHO COMING ALIVE.
20140503 173038 zpsg0xyszis
20140503 192045 zps7bymjx5l
20140504 100208 zpsw4rzj3mr
20140504 112730 zps9g5yqpaa
