Throw-out bearing retaining pin NLA?
Irish Pride
Irish Inside
MusicCityUSA
You can still find them online. I bought a box off ebay earlier this year. You just need to use something that is secure enough to hold the TOB in place while installing the trans but not so tight as to cause the clutch fork to bind when moving it back and forth. I've used roofing nails in the past. You could try a push pin. I just happened to have this near me and it would probably do the job.
-Chad
20240621 081232
Type47
@Chad
Thanks so much. We were eyeballing this last night and the consensus was that it did do anything functional. I downloaded the Service Manuals from Dropbox and confirm that it is in fact an assembly aid. I am planning to use a small zip tie to get this car off the lift.
DaveSHOtime
Los Angeles, CA
I've found out similar info, it's just to hold the TOB in place when installing the trans. I used a small piece of plastic to just secure it in place.
