Just to follow up on the c&l 73mm experiment. I thought I’d start out with the 73mm body and stock sensor from my SHO. Ran like ****. Lack of power, and poor throttle response. Felt like the fuel pump was bad.I’m going to install a 73mm C&L MAF from a Fox Body. I’m going swap out the sensor and retain the stock sensor in the larger body. Can I expect any problems. If so. What codes might it throw.
