marius883
Orlando, FL
There are several TSB's concerning hard shifts from time to time... they have a strategy update that smooths out those random hardshifts..
Really, the only video that is concerning is the knocking... with the 4+ tune at 91 octane it could be knocking if you got really bad tank of gas.... have you tried taking out the 3bar map and reverting back to stock to see if the knock goes away?
The transmission does the same thing in drive, it's worse 2nd to 3rd, it'll sometimes rev up to 3k then drop back to around 2500rpm.
In the video and for the past 2 months or so, I've actually been running the car stock, so in the video it is stock. Definitely concerns me. The service manager told me that the cleaning of the intake and throttle body and all that should fix it. If not they will look into it further.
StealBlueSho
NA
I would be shocked that cleaning the TB and Intake would fix that issue at all... I would get a second opinion before I shelled out money for them to spray TB cleaner..
Sent from my Nexus 6P using Tapatalk
marius883
Orlando, FL
I'm thinking the same thing, but I figured hey it won't hurt to have it cleaned anyways. I'll be putting new plugs in it as soon as I get it back.
C2_SHO
Did a datalog and sent up to Torrie, what I got back was nothing short of an amazing update to an already amazing tune! Came with a free stupid smile on my face. Also did a quick wash as we just came back from STL.
3bb973330eebd3223d307ea04aea2ffa
Sent from my SM-G935V using Tapatalk
marius883
Orlando, FL
Beautiful car!
marius883
Orlando, FL
Surprise surprise, they called me from the dealer, after the cleaning the knocking was still present so they want to keep it longer :bonk:
JasonoftheRugar
Wisconsin
Changed my diff oil. Came out golden. Been in there at least 20k miles. Not to mention lots of hard boost launches, street races and hard driving by me. Pulled the cover, dropped the exhaust a few inches to make it easier. Then I decide to just drill and tap a drain hole/plug. The thought of going thru that again irritated me. Found a nice area, drilled and used a 1/8 27npt tap. (Ptu is next for a drain plug) plug is the Same part # as our trans drain. Amsoil 75w90 severe gear. Need to clean the housing Ca095eb1a83b377af32da12cb9fc752c4031ebc735799cdf98406d6518b73e1f1e8991dca503e041948fef0c6c9afd14
Sent from my Nexus 6 using Tapatalk
So, where do you fill it then?
glockcoma
This is not my mod, I'm just some what familiar with the process.
The fill plug is already built in, you are adding a drain plug. Rule of thumb is to fill through the fill plug until the fluid starts to spill out from there. The official fill amount, assuming all old fluid has been evacuated is around 1.15L, I believe.
JasonoftheRugar
Wisconsin
Is there a gasket for the cover or just rtv?
RTV
Item ------------------- Specification
Clear Silicone Rubber ESB-M4G92-A
TA-32
