Zpak
Es Aich Oh!
The PP brakes also have larger rear rotors and a larger master cylinder bore. Also, recalibrated electric-assist steering for improved feedback.
@shoblock gave us that insight over a couple of posts over the years. Theory is PI cars do a lot of idling (I know you know this), then are subjected to full throttle pulls and other police driving activities. They needed a more durable piston. In post two below, Shoblock talks about the difference.Upgraded pistons......????
Do share, as I am unaware of any differentiation in pistons between the two packages.
Everything else you list is accurate though. So for that....
Sent from my SM-N986U1 using Tapatalk
This thread is a catch all. So no worries. The first part is all information for new SHO owners. The middle is all my upgrades, failures, and wins with the SHO. Now it has morphed into my Lexus build. I tried a thread on the Lexus forums but literally gets zero traffic. People here seem to like the Lexus, and a current SHO owner is tuning it...so it is guilty by association.great info here.. if the following is too off topic for this thread just tell me..
i havent seen an option for determining a part ie rear shock listed as w/painted calipers or wo/ painted calipers..
but apparently rock auto did it like that;
what gives with the "painted caliper" option and why does it change the shock choice
MOTORCRAFT ASH23479 Info
Rear; w/ Painted Calipers
MOTORCRAFT ASH23482 Info
Rear; w/o Painted Calipers
from this website url
2017 FORD TAURUS 3.5L V6 Turbocharged Shock / Strut | Shop Now at RockAuto
Suspension Parts and More for Your 2017 FORD TAURUS at Reliably Low Prices. Fast Online Catalog. DIY-Easy. Your Choice of Quality. Full Manufacturer Warranty.www.rockauto.com
tasca might be worse..This thread is a catch all. So no worries. The first part is all information for new SHO owners. The middle is all my upgrades, failures, and wins with the SHO. Now it has morphed into my Lexus build. I tried a thread on the Lexus forums but literally gets zero traffic. People here seem to like the Lexus, and a current SHO owner is tuning it...so it is guilty by association.
To answer your question. I usually reference everything through Tascaparts.com. I am not a Rock Auto fan. I find the website to be cumbersome. For the painted caliper question, I do not have an answer either. I have stock PP shocks and struts with H&R Springs.
i bet one of those is a misprint.. with it written like that there is no spring option for the withouttasca might be worse..
so according to tasca the painted caliper is not an indicator of the performance package since they are options for painted caliper with AND without the performance package
actually it is the opposite.. lol..
I thought the hydraulic cylinder was on the outside. Did they change the design?Lexus update: About two months I went a Lexus car show. Always a fun time. However on the way back, my clutch pedal decided it wanted to stay on the floor. I pulled over and checked it out....sure enough there was fluid trickling out of the bell housing.
I honestly don't know what failed. Either the slave or a busted hydraulic line is probably the culprit. However, I have to pull the transmission to even diagnose the problem fully. Hence, why it is still not fixed....lol. One of these days, I will get around to it. I did start it the other day, and I remember how cool it sounds.....
I run a twin disc. The slave bolts to the trans and goes around the input shaft. At this point it would be sweet if it was the stock external slave and fork system.I thought the hydraulic cylinder was on the outside. Did they change the design?
GB5Z9G440AAnybody ever change the turbo feed line filter screens for the **** of it?
Also, is there a PTU rebuild kit?
You probably should have made this it's own post instead of hijacking a post about another member's build. You'd get more responses that that way. But here's some PTU information that will have what you need.Anybody ever change the turbo feed line filter screens for the **** of it?
www.fortheworkshop.com
I was always told to make sure the battery is reading over 14v to be considered a normal healthy charged battery - I had that thread talking about a parasitic battery drain, and one thing I learned the hard way - remove the battery cable before charging, the BCM/security system stays awake when the hood isnt latched. As a side note - I grab my batteries from Costco - Interstate selling both traditional and AGM batteries with 3 year warranties. The best is they take them back so easily. So just before the 3 years - trade up.check it with my multi-meter...12.8 volts
SHO’s eat batteries for breakfast. I’m on #5. I can’t load a tune with the hood open, my extra fuse for the Fuel-It ethanol sensor plugged in, or the battery on a tender. Like you said, SHO stuff.
Interesting. I did have my hood open while I was trying upload the tune......Since both of you said that, that could have absolutely attributed to my troubles. However after the disconnect, charge, reconnect it did take the tune with the hood open.I was always told to make sure the battery is reading over 14v to be considered a normal healthy charged battery - I had that thread talking about a parasitic battery drain, and one thing I learned the hard way - remove the battery cable before charging, the BCM/security system stays awake when the hood isnt latched. As a side note - I grab my batteries from Costco - Interstate selling both traditional and AGM batteries with 3 year warranties. The best is they take them back so easily. So just before the 3 years - trade up.
