Rod Bearings.
Jrodm12
Wa State
Ok I am changing my rod bearings as there is a ticking noise from the underside of the car and it seems like insurance work anyway. Well I was curious on what parts i need exactly to do the job and how hard the job really is to do and what trouble or bumps i might hit in getting to or changing the bearings thanks.
91 Plus
Well-Known Member
Monroe,Michigan
You can get the bearings from Napa for pretty cheap. You will also need to get the oil pan gaskets,assembly ****, and rtv for the rest of the oil pan.
Also might want a can of pb plaster.I would soak the ypipe bolts for a few days before you try and take that off.That is usually that main problem with doing that job,if the ypipe has not been off in a while. Its a pretty easy job,just make sure you get all the right specs for the bearings and oil pan.Good Luck
Denny
Taurus Homeland
Atlanta, GA
Don't forget your trusty torque wrench :thumb: I'm not sure how hard it is with the engine in, but the actual bearing replacement isn't all that bad, just gotta be patient when getting in those top bearings.
Jrodm12
Wa State
Ok what gaskets do INEED specificaly do I need the oil pump pickup tube gasket and all and where do I get these. I am kinda on a tight budget dont wana spend over 100 bucks on this really.
TYSHO
Earth
Jrodm12 said:
Also where would I get a Exhuaust Flex Pipe Gasket? Plz don't tell me I got to go to dealer I HATE em.
Fel-Pro 60641 $5.29@O'Reilly's
Jrodm12
Wa State
do i need 2 flex pipe gaskets and anyone know if that EGR gasket will work for a pickup tube gasket?
Denny
Taurus Homeland
Atlanta, GA
Hey guys, he has an 89, he needs the donut gasket for the exhaust, not the flex pipe gasket...that is unless he wants to upgrade to the flexpipe
