Rod Bearings after 230k
gurucomputers
Everett, WA
Coming home from work last Wednesday I was sitting in some heavy traffic. I thought I noticed the oil light flicker ever so slightly. The first words that came out of my mouth was "I know that was the Battery Light"!! I turned on the dome light to see which light it was and sure enough it was the Oil Light, then I said "OH CENSORED!!!" Well I managed to get it the next 12 miles home without anymore flickering and no knock. Thursday I ordered new rod bearings and let the SHO sit till Sunday when I could make time to change. After I pulled them out I was surprised. They aren't as bad compared to others I have seen. The SHO is back on the road and healthy again.
Here is what they looked like:
matty
Southern Cali
hmmm
not to bad wish mine looked that good when i pulled mine,mine didnt have brass left
revhardSHO
Seattle, WA
We should make this a rod bearing picture thread, since you have a nice shot of your bearings and mileage. Here is my contribution:
196K, ATX, rod knock (can you guess which bearing?) and oil light flickering.
^The motor lives on with fresh bearings
160K, MTX, ran fine
Nice and smooth now!
93rev2sev
Hockeytown
Here's a set with about 145 on em...
The car now has 162,000 miles and runs strong with no oil light(unless I lug it below about 600RPM)
DCP01161
weewajr
chilliwack, B.C.
my oil light will just flicker ever so slightly when the engine is good and warm and only when it is completely settled into a idle. would that mean that my rod bearings are on the way out?
93rev2sev
Hockeytown
Yes. That's exactly what it means. Changing your rod bearings is the best thing you can do for your car for under $100.
gurucomputers
Everett, WA
Do it ASAP or you will regreat. Don't drive till completed. It only takes a matter of minutes to spin a bearing. Yes, I babied mine home but my eye was glued to the oil light. If it would have flickered again I would of towed it home.
itwonder
VA
Here's mine after 185K using Mobil 1. They were is pretty decent shape, never any oil light indications.
IMG 2494Medium
aggiesho
Houston, Texas
hummm, im a little worried that i have 202000 miles on the original rod bearings. maybe ill change them over christmas break, unless i have to work :(
adidas_kn
LOWSHO
Houston Texas
Do it! Don't delay! Act now! I killed 2 engines due to rod bearing failure. That was in my SHO infantsy. Now I always double check and then replace them in my engines.
