i'm not quite sure if the rod bearings are going out would you hear a noise all the time,or would it come and go. I got under the car with my car stethoscope,and listened very closely around the whole oil pan.I hear absolutely nothing bad.Sometimes when i'm in the car,I hear a rattling sound very slightly.the rattling comes and goes only when i push the pedal from idle.It does not do it all the time.Mostly my question is the bearings.Would you hear at idle in park? Or just when you put in drive and push the pedal? I have a 95 atx(112,000 miles)I don't know if the bearings were done.I can see that a new oil pan gasket and silicone were put on at one point.Thanks for any input on this repeated subject
