again, i’m as confident in my skills as you are in yours. who are you to tell me my measurements are off? have you checked them? or you just calculate measurements based off photos? please tyler, teach me. i find it hilarious your 37 year old self is this committed to refuting some measurements made by a teen.
I don't really give a c.rap about your measurements. We all think they're junk but that's just our insightful opinions based on the evidence presented. But what I've been trying to drive into that dense void skull of yours is that you don't even know what you're measuring or how to interpret (or disregard) the information. I'm obviously failing the mission. Here, let me try one last time, baby spoon edition. Open the hangar, here comes the airplane! BRRRRRRRRrrrrrrrrrrRRRRRRRRrrrrrrrrrrrr...
Let's spell this out one step at a time, referencing the shop manual and the information you've given thus far.
SECTION 303-00: Engine System — General Information
GENERAL PROCEDURES
Piston Ring End Gap
Use a piston without rings to push a piston ring in a cylinder to the bottom of ring travel.
yes, centered in bore with the piston.
Are you properly positioning the rings in the correct position for measuring?
No.
Now this: (see if this doesn't resonate with our comments to you)
NOTE
The cylinder bore must be within specification for taper and out-of-round.
Refer to the appropriate Section 303-01 for the specification.
Ok lets dissect that a little bit...
SECTION 303-01B: Engine — 3.5L GTDI
Cylinder bore diameter 92.500-92.520 mm (3.641-3.642 in)
3.64” side to side 3.642” top to bottom
Is the bore diameter within specification?
No.
Cylinder Bore Out-of-Round
NOTE
Measure the cylinder bore in 2 directions. The difference is the out-of-round.
Cylinder bore roundness 0.013 mm (0.0005 in)
Is the bore out-of-round within specification?
No.
Cylinder Bore Taper
NOTE
Measure the cylinder bore at the top, middle and bottom of piston ring travel in 2 directions as indicated. Verify the cylinder bore is within the wear limit. The difference indicates the cylinder bore taper. If the cylinder bore taper does not meet specification, bore the cylinder to the next oversize limit.
Cylinder bore taper 0.010 mm (0.0004 in) per 25.4 mm (1 in)
Taper = 0.00?? I don't know what a tenth of a thou even is!
Is the bore taper within specification?
Nobody knows. But who needs precision measurement when ya got
CONFIDENCE!?!
In summation- is your bore within specification?
No.
Now this really should go without saying, but BRRRRRrrrrrrrrrrRRRRRRrrrrrr.... a manufacturer specification for ring gap is only applicable to... wait for it... factory new rings! The chart
@yaycandy showed you (BTW no chart needed, it's easy as Pi) is applicable to both cylinder bore and radial ring thickness cumulatively. It takes only 0.0005" surface wear on the cylinder and 0.0005" surface wear on the ring to open the ring gap by over 0.006". Not to mention, this is all being done on the basis that you believe your ring ends butted, which would have distorted them, affecting tolerances. This point alone demonstrates just how asinine this whole excercise is. You can't forensically tear down a worn or damaged engine and try to measure what the tolerances "used to be". That's why builders use build sheets to record all the relevant information before the machine is assembled, to have something to look back on if there's a failure.
SECTION 303-01B: Engine -- 3.5L GTDI
Piston ring width — upper comp ring 1.17-1.19 mm (0.0460-0.0468 in)
radial width -- ????
ring is .017” thick.
Are your rings factory new?
No. Do your ring measurements even remotely resemble factory spec?
No. Are you equipped to accurately declare the spec conformance of your cylinders?
No.
Do your flippant feeler gauge follies have any relevance whatsoever? NO, NO, NO, NO, NO, NO, NO, and NO.
Are you full yet, you little brat? Can we wipe the dribble off your chin now? Or do we need to get the ni.pple out?
