New ?'s About 60K
MI-SHOFEAR
I'LL SHO YOU
Farmington Hills MI
I will be doing my 60K this summer because i dont know if it has ever been done on my SHO. I was wondering a few things before I get started. Just need some advice.
Parts I have already replaced:
Belts(MTX)
Waterpump
Upper, lower rad. hoses
Batt.
Parts I will be replacing:
o2's
CPS
Timing Belt
Valve cover gasket set w/plug well gaskets
Alternator
plugs
wires
Parts im not sure about:
Why is it importand to adjust the valves? Am i correct when I say they are a Hyd/Flat tappet design? If so, shouldnt they adjust with oil pressure and as they wear, or do they wear to a point that they need to be shimmed?
Am I missing anything else important?
Thanks for the help guys,
Jeff
MI-SHOFEAR
I'LL SHO YOU
Farmington Hills MI
I think I misprinted. Are there Lifters built ontop of the valves that are hyd. or are they a solid design.
Chime in anytime perry.
Jeff
Denny
Taurus Homeland
Atlanta, GA
Solid design.
If you want, I am the new Michigan 60K guru since Chris moved out of state this summer :evilgrin:
Cobraii976
I am an idiot
Or Call Bill and I were doing or 12th sometime in the next month. And **** I'll do one on a spare engine just for fun if you want to see one. Takes about an hour... But informative.
Mr Anonymous
Tire Wall
Jeff
Solid bucket tappets, which use shims that are a lesser hardness than the cam lobes so they will wear instead of the cam lobes.
Why are you replacing the alternator? It is generally not a 60K maintenance item, and if it's failing now, you need to replace it now or you're going to ruin the new battery you've installed.
MI-SHOFEAR
I'LL SHO YOU
Farmington Hills MI
Its flaky, every once in a while(week) the batt. light will come on for about a min or two. A supplier of mine rebuilds alternators and said he can up the amprage a bit to help out the needs of the stereo. Ill do it while im in there. I also need to replace the AC compressor and lines but that is way expensive
Jeff
