mrsolo2000
Rebuilding a 3.2l. Main bearings look good and within desired clearance. New rod bearings and those are in clearance. New piston rings and cylinders were honed. All torque values meet on crank and rod bearing caps. The full rotating assembly seems way too hard to turn by hand. However, it will fully rotate. I started to remove a piston and it doesn't want to come out very easily. Should there be this much resistance with new rings and rod bearings?
This is my first time so any insight would be appreciated.
