Might have just ruined my engine during rebuild.
marshallma0504
Midland MI
So today as some of you know I was continuing my rainy timing chain rebuild project. I didn’t have a car to get to the store (obviously) so I didn’t have a puller for the harmonic balancer. Instead I used a 1 1/2 inch socket and a hammer with some padding on the balancer. Now I’m freaking out looking all over the internet as everyone says not to do it. However I didn’t hammer very hard, moderate force only and a few taps at a time and then checked the alignment to make sure it was going on straight. Once it got close I put the bolt in and drew it in by hand no impact. Everything was lined with clean oil before starting. My question for any experienced engine builders, how f-ed am I? I feel like a darn fool right now thinking I knew this project back to front with the manual and I might have just ruined my crank bearings. Honest answers would be appreciated.
marshallma0504
Midland MI
Edit:
I just re watched ford tech makuloko’s video on the f150 and he tapped his on with a socket and then used the old bolt to draw it in. So I’m probably just overthinking it, but I won’t be tapping it on again. At least I didn’t go wailing on it with a sledge.
kryptto
South East, Florida
Edit:
Can't say haven't done it...
FrankK
Colorado Springs, Co
If you have ever looked at how well secured the main bearing are set in the EcoBoost you should have no worries about a few taps.
IMHO
marshallma0504
Midland MI
IMHO
Thank you. I appreciate that a lot. I tried researching it on the eco posts but nobody seemed to have an answer other than “it’s not recommended.” Which I knew going into it hence why I took precautions with the padding and the little taps in the center and the oil. I also knew not to heat it in the oven to avoid destroying the rubber.
boookboy
Staff online
