Engine bog
016SHO
Hi,
I just purchased my first SHO (89 5spd) last year from someone who let it sit in the sun the last 10 years. Admittedly, the engine has less than 40k miles, and the rest of the car less than 80 (towed behind a camper). After a bunch of new parts were put into it (including a new fuel pump), it seemed to run pretty well. Lately it has been doing a bit of a stutter while driving. I'll be cruising along and the car will shake as if you just took the foot off of the gas. It will do this 3 or so times and quit for a bit. Flooring it will cause it to stop the stutter, but it seems to do it again to fulfill the set (of 3 or so). I was wondering if perhaps the new fuel pump was at fault? The gas tank certainly sucks air when I remove the cap to fill up. However, removing the gas cap did not stop it while driving. Also, it idles pretty well.
As a side note, most of the dash cluster lights don't work, but the gauges do. How difficult is it to rewire/replace the dash cluster? When they towed it, they spliced into the harness to wire lights so the dash panel dim would turn off/on the radio.
I would love to hear any feedback.
sperold
Last to Know
When you say "quit for a bit", do you mean quit stuttering or quit running?
Look for codes stored in your powertrain computer. There is a paper clip method that you can search for on this forum or go to Shopowered.com and find it there.
Do a pressure test on your fuel pump at the schrader valve on the fuel rail on top of the engine. It should be 40 or so psig at all reasonable rpms. The regular Taurus pump will work but is a little weak, so it could be the issue. But the pressure test will help on that.
Get an Electrical and Vacuum Troubleshooting Manual (EVTM) from sellers on E-Bay, should be around $20.00 or maybe less for the 89 Taurus. You will be able to fix-up the wiring where the splices were performed.
016SHO
When I say quit, I mean the car quits stuttering. Having driven it again since posting, it seems to have gotten worse.
I'm going to be away from my garage for awhile, so I won't be able to properly work on it until this winter, so I will probably leave it parked until then.
Thank you for all of the information, I'm sorry that it will be awhile before I can post an update.
hosbaldosho
