Got the crank pulley removed. It's not as warm as yesterday, so I am warming up grabbing some lunch. The sensor is supposed to be out for delivery, so I expect it in the next hour. Are you guys able to move to rotating assembly with the timing belt? I will get this sensor removed, so I can test along side the new one, and hopefully give a thorough inspection, and start reassembly. I felt that the crankshaft pulley only needed to pull a little bit, until it was loose? Is this common? When I pulled the one on my truck, it seems like it might of tried to fight me most of the way off the shaft. But, that was a harmonic balancer, the pulley is separate. The previous owner did state he was in there replacing the sensor?
Sent from my SM-S236DL using Tapatalk
