FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Starting to really hate the battery management system... started popping a warning and shutting down the car maybe once a month, then once a week, then once a day. Did the BMS reset in Forscan, seemed to help for a few days now its giving audible warnings and displaying the battery light every time I turn the car on without starting and as soon as I turn the car off.
Been to the parts store to check it out, battery and alternator test fine. Started first try even when it was -10 out. About ready to disable the dang thing.
Michigan-SHO
Michigan
What exactly Does the battery management do?
Majestic
Yes, it sucks. I think the intention was to "save" your battery by intelligently charging it, like a trickle charger. I think it actually causes issues with batteries because it never keeps them properly charged.
BweegN
Springfield, VT
Decided to paint my strut brace and battery tie down today, was bored. Pretty happy the way it turned out i will post a after pic as soon at its dry to the touch 7b190e4dddc6cf272655d9217387399f05d2e29ef7ff33024e5f9ee485386c7050f111034bfbb443e0ac108155c610724e01e07416f8cb071b9c1a519ea22d24
LOVING THIS!!!
Since my car is going to be ripped apart I think i'll do the same and include the battery box and intake mount. Well done!
Roman
Mi
LOVING THIS!!!
Thank you! I'm more the DIY guy more than anything I'd rather do it myself then buy it! I'm excited to see your build once you're started
FiveLeeter918
Tulsa, OK
It's designed to monitor leakage and shut down the system to prevent you from coming out to a dead batter. So if you leave a light on, if it notices that your radar detector is causing parasitic loss, etc. it will shut off after 10 minutes to prevent you from killing the battery.
I replaced the battery last year and reset the system, but it started doing it back in June and is progressively getting worse. I put it on a trickle charger today and hooked up Forscan to disable it completely, but then started going through my head of "what ifs" and "what if there IS an issue and I disable this then my battery does die and I'm stranded somewhere?" so I decided not to.
Wsho
Sacramento California
Another day another project completed I think. This was the biggest pain in the ass thing I did now. I know why the upholstery shops did not want to do this. I'm a little ****** off because the guy picked out and order to same color as mine interior. Well apparently it's not the same color so I did both pillars the match. .
63675477931  6DD7222D 62DC 439D 9407 AFA87740863B 63675701258  4628F1FB 5B49 42B9 B149 C0592472597A
Nova
US
Well....where are the end result pictures!?!?!Tltngqatejy1xibhyr12i0xqjd5g2zht63aqaq8pridgiphy
RoketRdr
Houston
Use Forscan and just turn it off. :thumb:
RoketRdr
Houston
Its primary purpose is to shut down the alternator for increased fuel economy. It will only charge the battery to 80% and then shut off. Then it cycles on/off while driving to keep the battery at 80%. As you drive ,the system switches back and forth between battery and alternator depending on load. If you disable it, the parasitic auto shut down feature still works and you will get 100% charge rate to the battery. If you ever upgrade your stereo with amps you'll want the BMS disabled.
