Random harsh shift/bang
Deezuz
Indiana
This has only happened once, but I started the car, put it in gear and rolled out of my driveway, moderate throttle and I want to say coming out of 2nd gear there was a BANG feel. I can't even really describe it 100% cause it was so fast so random. No lights, no rough run.. I pulled over real quick, pulled back out and absolutely nothing after wards.
The trans shifts so smooth and firm at all times, I really could've never ever expected this to happen.
Is this a sign the PTU is going?
Csbbrah
Ky
Hard to say for certain. Any propane or gear oil smell going on? If it was PTU I would say it would be reproducable at least in my case it was.
Sounds like a good time to so a trans drain and fill. Aswell as a PTU fluid change.
Sent from my LM-Q610(FGN) using Tapatalk
Deezuz
Indiana
Both fluids were done 3k ago, car had 113k. Trans fluid was clean and ptu was def dark but it was still very strong viscosity wise.
yaycandy
Aerospace Engineer
Hanover, PA
I had some clunks and one bang after putting redline in my ptu. After research and looking at everything, I did another ptu fluid change with amsoil and it hasn't happened since. My shop put redline in when I asked for it to be changed. Then I went on amsoils website and put the ptu fluid that it said to run and that issue went away. Hasn't clunked or banged in a gear since.
What fluid did you put in?
ridered74
When I had my 2011 I had somewhat similar happen twice, but mine happened both times when I gave it a slight amount of gas, coasted for a second or two and then tried to accelerate hard. It started to accelerate but then made a loud noise and then it was like I was in neutral. That happened when it was stock and just over 100K miles. I just never eased off the throttle and then romped on it immediately after that and it never happened again. Not sure if it was coincidence or what, but I drove 60K + miles after that no issues.
GrizzySho13
Chicago
CHECK REAR DIFF, I was having the same problem I swapped out PTU ,shocks and struts complete front end , cv axles and finally found that it was the darn RDU rear differential unit .
Deezuz
Indiana
Boy does this kinda sound like what I did!
Thinking it was just a fluke
