bpd1151
Lurking Around
SHOcago 'Burbs
That wheel and tire combo looks awesome! What are the tire sizes? Is that lowered? Thanks, hope all is well.
Sent from my LG-H831 using Tapatalk
Staggered set up......
255/45 ZR20's up front, on 8.5's.
275/40 ZR20's in rear, on 10's.
Yes, lowered on Megan Racing rollovers.
About 2 1/4" drop in rear. About 1 3/4" up front.
COMpulse
Detroit Area
My splash-sheild was damaged by a rock on the freeway causing it to hang down. Needless to say, it got torn apart in the snow:
SHO SplashShield Broken
So I ordered a new one for around $100:
SHO SplashShield New
The new one did not come with the sound-dampening material that the old one had. And the old one seems to be made of fiberglass or some fibrous material. The new one is flimsier plastic.
SHO SplashShield Compare
And the screws that hold this thing on are stupid. First, the new one didn't come with the special screws, so I was lucky to still have the broken pieces of the old shield to retrieve the screws. The screws are ridiculous. They have some hard plastic cylinder around half the screw, and a hammer is the only way to separate them. Then to get them back together (around the new shielding) I used a vise. Sorry no pics of the screws. But they were designed by the kind of person that hates everything. They screw into metal retainer clips that are also stupid.
I later found out I could have gotten a metal skid-plate for an interceptor instead. Not sure if that replaces this, or if it would go over this. I think it would replace this. I wish I'd gone that route.
COMpulse
Detroit Area
No idea why I didn't get OEM.
I just haphazardly purchased the first part I found when I searched. I'm normally smarter than that.
boosted4SHO
Atlanta, GA
Got the car back from the local Ford dealer. PTU went out at 74k. 2300$ later she's back on the road. Replaced the halfshaft and the lower under shield as well while it was there. Cleaned it up as soon as I got it back.
6bYUVl96miZNWGF7kncnQFwqp0p8ghANmvU5Pw850 h637 no
bpd1151
Lurking Around
SHOcago 'Burbs
Decided to pull the trigger on a new pair of LED projector puddle lamps the other day.
These to replace my original set that I gutted open way back in 2010, and authored a "How-To" tutorial on how to retro the LED into the housing.
I couldn't resist these, as the projector portion casts the FORD oval/logo onto the ground below it. Looks really sharp.
The things that are being done in the lighting department never cease to amaze me. Cool stuff.
Installed them just now......
208fb929d31912829a6809df3d95aeed62b01bdafca9ee94cf0f8c0b6336bfd74f724edeabf6d03fa3846ff08a8f2e7c9afdbb0818ce39ee4770b9ee19eb2afc4a94620b60abd63a639364eeb6bf20cf13d8365ba08421aae393d206f7e7a107
Matt M PA
Hey...those puddle lamps are great! I assume the old ones simply pop out from the bottom?
bpd1151
Lurking Around
SHOcago 'Burbs
Yes. There's an expandable tab on one side, that once inserted into the mirror housing it will 'snap or 'click' into place.
To remove from the mirror housing, just pinch that same tab together to extract the puddle lamp.
Glad you like. I do too. Like I said, sharp and always amazing to see the developments in lighting effects.
Juicybaka
Did these fill the opening nicely, or was there a gap? Also, can you please post link. Thank you
Matt M PA
I found them on eBay...
And...a question. Hows does the actual illumination compare to the originals? I never took notice of how bright, wide, etc the pattern is on the factory ones. (Haven't driven my car much yet...but with rain over the next two days the salt should be gone!!!)
bpd1151
Lurking Around
SHOcago 'Burbs
Well, if you recall, the originals were dim, yellow colored halogens.
I gut them open, and retro-fitted my own LED's many, many years ago.
The light from this new product is bright, but it's more precise and/or crisp. Not an all over the place, non-descript light.
I would say they don't appear as bright as my formerly chosen LED's, but that's because the pattern is more defined and direct.
If that makes any sense??
Matt M PA
Yes, that does make sense. Thanks. I got my SHO in December and have been waiting for the salt to be gone before it goes to daily driver status....so I don't know how bright the factory ones are....I just never noticed.
bpd1151
Lurking Around
SHOcago 'Burbs
Well today was a busy day for my SHO.
Started with changing out the puddle lamps (see/refer earlier post from this morning).
Performed an oil change and in doing so, noticed I had two small meth leaks. Christ's sake.
One leak was on the OEM Washer Reservoir. The low tank sensor grommet degrades over time. So off with that piece, drain all the meth, then slap a new grommet in place, clean up the old sealant, then re-install and re-seal.
The 2nd leak was on the pump itself. Pretty common place. If you recall I learned back in Summer of 2014, that ALL METH PUMPS (regardless of the mfg'er) have a life span. Typically 2.5-3yrs.
At that time (Summer of 2014) I replaced that pump with a new one, then had my original pump from 2011, sent back to Alky Controls for rebuild.
So I got 3yrs out of the 1st pump, and almost 4yrs out of the second pump.
I'll send the 2014 new pump in for rebuild, and will feel confident that the current one will last another 3yrs.
But WHEW. Good Lord. My lower back is starting to feel it after having spent so much personal, intimate time with the SHO today.
No spring chicken anymore, lemme tell 'ya.
markmoomnu
