13:1 Compression 3.3L cam'n its ass off
zach44102
BIG TURBO
Georgia
So i have not updated for a while but the motor is coming along pretty smoothly. Got the heads bolted on, cams installed, bottom end all assembled, half of the valves are adjusted but for the other half im going to need some pretty odd sized shims. Also got some accessories bolted on and finally gutted the AC compressor. Waiting on a timing tensioner stud, water pump, timing belt, timing belt tensioner, valve cover gaskets, valve cover grommets, oil pickup tube gasket and the oil cooler to block gasket. All ordered from www.SHOsouce.com. :thumb:
20131222 014835 zpsbd6abaf4
20131222 014858 zpsba55fa86
20131222 014919 zps9b8e8253
20131228 230128 zps065aeae3
20131228 230141 zpsdfcbacc4
FB IMG 13885524640434516 zpscaa52f01
zach44102
BIG TURBO
Georgia
Got some new parts
NIB TIMING belt tensioner.
20140110 100210 RichtoneHDR zpsb118c12b
new timing tensioner stud and a Alternator bracket I was missing.
20140117 144934 zpsdd9216b8
And lastly the new water pump, timing belt, oil cooler to block gasket, SHO SOURCE valve cover gaskets and grommets.
20140107 185829 zpsa89b59fa
PROPHET
Well-Known Member
Tonytown, Texas.
I come back to the forum after a few years and everyone is blowing or stroking something.
:swing:
revhardSHO
Seattle, WA
Moter looks great. How far off are you from having the car completed?
I guess with a SHO that's relative. you fix one problem and ten more crop up overnight. what are you doing for half shafts and any concern with 3rd gear. I know it mostly effects boosted SHOs. Donno if any NA cars have shredded 3rd yet.
keep up the good work. :thumb:
intimdatr
Got Cams?
Jefferson City, Missouri
Yup, they have. And he was the one to do it.
zach44102
BIG TURBO
Georgia
Already broke third once. But the car weighs 2600 pounds now. Not too worried about breaking axles. More scared for input shafts.
shobroooo
