SHOblime
Hey, I have a known valve cover gasket leak and plug well seal leak, however, after driving about 120 miles last night, as I was pulling back into the driveway, I noticed a large amount of white smoke coming from under the hood. Went to bed. This morning, overflow tank is empty (not sure where it was yesterday), no signs or bhg, basically I need to do a coolant system pressure test and a compression test and see what's wrong? It's probably either a BHG or radiator end tank, correct? Also, where is a value priced temp sensor to be found? My temp gauge doesn't work
