venom
Rowboat Design
The countour pedal set can be carved up and added to the SHO pedal set. You essentially need to cut the left side of the Contour pedal set off and weld it on the left side of the SHO pedal set. Then some hardware and bushings and you can extend the bolt through the added Contour brake pedal.
Another option is to take a gen 2 pedal set from a MTX and modify it to hold the clutch master cylinder. I am told that the gen 2 pedal set just bolts up. Regardless the fuse box needs its position adjusted to allow space for the clutch pedal.
Hope that helps.
Hope that helps.
