What makes a DIS pop?
zach44102
BIG TURBO
Georgia
OK second problem i have had with getting spark on my 3.2. A couple nights ago the sho broke down, just quit. No spittering, no sputtering. I checked for spark and had none, ten mins later the car started back up and drove for 2-3 mins and quit again. I let it sit for 10--15 mins and it started back up and ran for another mile and quit. My first thought was the CPS because thats usually the symptoms of coolant leaking on the cps. Well i replaced the cps and still no start, So i replaced the Cam sensor with another one i had and still had no spark. On my last problem with spark i swapped in a new dis which fixed it so i have a new dis. I pulled the codes and got 126,551,556. only one that i noticed really was 556 which is fuel pump relay (ccrm??) but i do have fuel pressure. 39 psi at the rails. What did i do wrong? any advice?
Westerly, RI
Check for pinched wire harnesses at the bellhousing. Check the coil power wire to make sure the coil is getting powered. Re-check all your grounds.
zach44102
BIG TURBO
Georgia
What is this i read about gaping the CPS? would that have anything to do with it?
VortecGT
Wisconsin
I don't remember the gap but it is really small and im sure does play a role. Dude I would try a new coil pack next.
zach44102
BIG TURBO
Georgia
Just got the DIs tested it came up bad (if they tested it right) I swapped on another DIS which i got from mark nunnaly and it still does not fire, i guess im going to go get this one tested too.
zach44102
BIG TURBO
Georgia
Zach, There is a possibility you may have overheated the DIS. Did you apply Heat Sink between the DIS and the Intake?
-Sam
I applied di-electric grease.
Update: I just got back from testing mark nunnalys DIS and it hd mixed results, we tested it about ten times, 3-4 of the times one of the 6 lights did not light up. on the other 6-7 tries it passed with flying colors, But with the new dis on i still had no spark, So im putting the original Cam sensor on the car instead of the spare one which i have no clue is good or not. And if that does not fix it Ill pull the crank pulley off and check the cps again.
AREA 91
PA SHO SHOP
Area 91
The car should start without a cam sensor.
The gap for the crank sensor is .030
Do you have 12 volts at the coil pack? I believe it's a red&green wire.
zach44102
BIG TURBO
Georgia
I replaced the cam sensor and still no go, Im going to pull off the crank pulley and inspect the CPS. im not really sure how you gap a cps but could this cause a no start (obviosly if it sliced off the sensor)....
jayro
Auburn, In
You put a feeler gauge in the groove of the cps and gap it between the top of the cps and the veins on the crank sprocket. Ive killed a cps with the viens before. I would check voltage at the coil pack and work your way back.
trainguy1989
SHOtarted
Wichita, Ks
Source: SHO Phoenix Project
Like this:
kevinspann
Don't take my advice.
Richmond VA
I've just used the smallest part of one of those cheap round spark plug gapping tools to gap the CPS, if you don't have any kind of feeler gauges.
91PDXmocha
Portland , Oregon
A business card has worked well for me on multiple occasions . Did you check to make sure that the balancer is seated all the way on? If its out 1/4-1/2 inch the car will not get spark.
zach44102
BIG TURBO
Georgia
I have the crank bolt tourqued all the way with a impact wrench, 6$ buys me a feeler gauge so im going to take car of that tomorow, hopefully it fixes the problem. Also I cant seem to work the slack out of my timing belt. I plan on checking out the tensioner a little more but i got all three marks dead on and there is still slack in between the pulleys. Im thinking i need a new belt.
