musiccitysho
I pulled the codes on my 93 atx because of stumbling through gears when reaching normal temp and a CE light.(It runs through gears fine when cool) I had the vss code stored in KOEO.
The problem is that the cruise control functions properly and I had the vss replaced less than 20,000 miles ago. I pulled the wheel and checked the connection, nothing seemed to be dripping on it and it felt secure, although my vision was limited, the rest I had to feel out.
Does anybody know what else could be causing a low input signal from the vss, or where the wire harness routes. 20,000 miles seems like a awfully short life for a sensor and I would hate to lose all the skin replacing it again and find out it isnt the problem.
Thanks for any leads.
