Upgrade to SYNC 3.4!
Definitely the rhinestones, and I suspect cowboy boots as well.
Haha, I enjoy some Glen Campbell, and I do not own a pair of cowboy boots. The majority of the time my feet resident in Dansko's or flip flops.
However, I should have took Toby Keith's advice and "I should have been a cowboy".
Michigan-SHO
Michigan
You workout barefoot? I know a lot of lifters do
SHOthyme
MN
Its for NAV in Motion. Since it's technically illegal here I may or may not have switched to the European logic in order to disable it haha
Dang it, why couldn't you just say you were on the Autobahn?
Now I want it and I don't even know what it is!!!!
SHOthyme
MN
Scratch that, just looked it up, probably better if I don't have the ability to tinker with it while the vehicle is moving.
Joshw0000
North Carolina
I googled it too, lol. Looks like a plug can be purchased for a couple hundred bucks to allow it. I did a little hackery on my truck (aftermarket radio) and installed a grounded switch so I could access some features while it's moving. It basically just tricks the unit into thinking you've pulled the ebrake. I'm sure that plug is doing something similar.
Sent from my SM-N960U using Tapatalk
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
Forscan is free though. :)
Joshw0000
North Carolina
I tried it once to get rid of Sirius from my stereo and it wouldn't work with my ELM327 OBD2 (cheapo eBay) bluetooth dongle. I tried the free app and a patched (err, try-before-you-buy) premium app. I know the dongle is good. I've used it to check/clear codes on a few vehicles with Torque Pro. But I guess the app just didn't like my dongle.
Forscan's site recommends a $100 OBDLink on Amazon. Which one do you use?
Michigan-SHO
Michigan
Did the update last night, didn’t go so well.
2016 SHO original SYNC 3.0 with navigation.
First, let me say the video and directions were spot on and I had Zero issues with this part.
However, I forgot to click the navigation box during the install process so right note I have no navigation. This should be fixed today when I download the correct files with the navigation
Problem number two, my USB ports in my center console no longer work, the error code says they are not supported. Further inspection reveals later 2016 models and up have a different USB port that supports Android auto and Apple car play.
Lastly, my clock is now 4 hours ahead and I cannot change it. I can move the numbers but in about five seconds the time blinks back to what it was before.
Good times....
FiveLeeter918
Tulsa, OK
Good times....
yea unfortunately you'll need to upgrade those for the update. I should've specified.
you'll need these.
https://www.tascaparts.com/oem-parts/ford-transceiver-gj7z19a387b
https://www.tascaparts.com/oem-parts/ford-control-module-bezel-gc3z19c149a
SHOthyme
MN
dan.delargy
