This is bad fuel pump, am I correct?
MelectroK
Michigan
Hello this is my first post, hopefully yall can help me please.
I beleive I have a bad fuel pump, but a new sending unit is $125 and requires pulling the tank. Am I accurate with my assumtion?
Case 1- Last two tanks of gas, when under 1/4 tank, excessive cranking required to start. Cycling ignition on-off 3 or 4 times usually started fine then.
Case 2- Two days before problem, noticed extreme loud screaming from fuel pump. (thought it was going bad based on another post here, but not expecting it that soon).
Case 3- Before main problem. 3 or 4 times right after starting constant idle problems, from 400rpm to 1000rpm up and down in pulses.
Case 4- Car will not run. Starts, same RPM problem then car stalls out. Re-crank and rpm continues to pulsate even when given throttle and stalls out. Buddy tells me when its pulsing he cannot hear the fuel pump winding.
After cooling the car did run again to get it back home. However have not been able to recreate the problem in hopes to check voltage at the cytriphical switch (which i have checked first when it didnt run) I know checking power after the cytriphical switch would tell me for sure if it is a power or pump problem (also know relay is in a module i beleive).
So is my assumption correct or do you have other ideas?
(sorry for the long post)
Mike
95MTX
poffffd
