Stalling issue
e_clouser
04DrpTopGT
Near Harrisburg, PA
After my 3.2 swap went well and the SHO passed state inspection, the old gremlins are back.
What happens:
Does not matter if the car is hot or cold, has no impact on performance.
Driving along, various situations, never the same, the car will just die, no stumble nothing, sometimes it will start right back up. If it does not start back up, If I pull the codes, it will start right up. I always get the same two codes. The car can go for days without doing it. And some days it is every 5 minutes of driving.
Codes are as follows
211 pip circuit failure
524 fuel pump related
Now before everyone tells me to change my cps, know that it has been changed and the problem still exists. Any Ideas?
93rev2sev
Hockeytown
Maybe the crank sensor is getting too hot, maybe the water pump is ******* on it.
In any case, the problem is the crank sensor
e_clouser
04DrpTopGT
Near Harrisburg, PA
I assure you that the water pump is new and not leaking, as stated, I started with this problem, replaced the cps last night, and it still stalls. I did notice that the 3.2 runs a little hotter then my 3.0 did, but not enough for me to worry
e_clouser
04DrpTopGT
Near Harrisburg, PA
the wire on the old cps was fine, and I really don't think I would have pinched the new one... maybe I got a bad cps in a new box....
