Ta2dResqr
Central Ohio
Curious to see the answers, as I have somehow locked myself into the guest My Key mode. I'm in the same boat, only have one key fob and was fiddling around in the My Key settings and now have my radio volume limited to half and have found no way to Deactivate MyKey.
If I remember correctly, you only need 1 Admin key to disable MyKey. So, if you bought the Dorman product above, you could use that to disable MyKey. I believe it can be done with ForScan as well.
Ta2dResqr
Central Ohio
He said you gotta buy key from Ford and program it
Not true. A Ford MECHANIC would say that because that is where they work and going by the book with the proper tools. However, the Dorman product works great. I have used it on 2 vehicles. I also had a friend get the Hyundai version for their SUV and it worked great.
Ta2dResqr
Central Ohio
If you need another key fob, you will also need to buy the emergency key that fits inside the fob, and get it cut. I had to get one when my wife misplaced, (lost) one. It was somewhat expensive from the dealer.
Most hardware shops and locksmiths can cut the key if you want the emergency key.
kryptto
South East, Florida
Take the passenger tire off - take inside passenger splash shield out of the wheel well. From there - not too bad. When you gain access to the turbos - feel if there is any wiggle in the wheel - or are they tight and in place.
@TheOGScooby other items to know. Might want to have a propane torch - trick to removing rusted or very frozen exhaust nuts - heat up the exhaust with engine running, then get under and WD40 or other lubricant spray the nuts down and let soak. Turn engine off of course - the heat helps with the penetrating oil.
If you get a nut that wont break free - torch the nut, spray again and dont wait try and back it off. Usually breaks free after a good torching. Get the O2 sensors off and out of the way - and label them. The wires are different colors - but label them. Upstream ones are wideband, downstream are not. Wrap those pipes even if you got them coated https://www.amazon.com/gp/product/B07WHMYK74/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
ALSO wear nitrile gloves when wrapping, those two rolls come with stainless steel ties. The ties are razor sharp and the fiberlass will get you nice and itchy. Long sleeves when handling wrap and gloves.
LASTLY - https://www.harborfreight.com/3-8-eighth-inch-offset-oxygen-sensor-wrench-97177.html
Joshw0000
North Carolina
@Joshw0000 other items to know. Might want to have a propane torch - trick to removing rusted or very frozen exhaust nute - heat up the exhaust with engine running, then get under and WD40 or other lubricant spray the nuts down and let soak. If you get a nut that wont break free torch the nut, spray again and dont wait try and back it off. Usually breaks free after a good torching. Get the O2 sensors off and out of the way - and label them. The wires are different colors - but label them. Upstream ones are wideband, downstream are not. Wrap those pipes even if you got them coated https://www.amazon.com/gp/product/B07WHMYK74/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
ALSO wear nitrile gloves when wrapping, those two rolls come with stainless steel ties. The ties are razor shard and the fiberlass will get you nice and itchy. Long sleeves when handling wrap and gloves.
Thanks but I think this one is for Scooby.
Sent from my Pixel 7 Pro using Tapatalk
Joshw0000
North Carolina
jman1200
Ontario
At least you didn't lock yourself to 20mph... lol
Joshw0000
North Carolina
First time I had to use the spare tire. Luckily I made it to a mostly open parking lot so it didn't take long to swap out. Tonight.....we plug!8aaa4182f6be627bdb670ac6e00bab5b
Boochy47
Michigan
That’s what I gotta do it’s sucks but I gotta
kryptto
South East, Florida
I took the wrong fob set as valet and was stuck at 45mph for 20 minute drive.... ugh
So I didn't know I had the wrong fob, most of the residential speeds were under 35. I was going to an appt so I didn't want to be late. For someone who likes to get a breakaway from the pack moment...... I was soooooo ******. I think the car barks at you too which made me more mad. It was painful.
Joshw0000
North Carolina
Today I changed the oil and cleaned the air filter. I started working from home about 4 or 5 months ago (with the exception of going into the office one week per month or so) and still can't get over how much more productive I am around the house.
I got home early from dropping the kids off at school so I decided to put the car on the ramps, drain the oil/dump the catch can, and clean the air filter. Then on my lunch break, I installed the new oil filter, topped off the oil, and sprayed / installed the air filter.
I even had enough time to whip out the pressure washer and clean up the kiddos go kart and fourwheeler.
There is something to be said about getting out of the rat race of going to an office ect.....
Joshw0000
North Carolina
Yes sir. This new job was a God send. I was so burned out at my old job and had been looking with no luck. I wanted out of customer service and into IT but had never held an IT "position". I just did my job plus whatever system stuff they needed.
One day I got an email (at work) from the head of the ERP system we had cancelled a year or two back asking me if I was interested. My interview was him telling me about the job over the phone and asking me if I was interested (we had worked together for 7+ years). I said "yes" and he said he'd email me a job offer by the end of the week. The offer was fair, the insurance is phenomenal (100% paid by the company for my family and I - Humana), and I was to meet him at my first customer's business in 2 weeks. After about 9 months in the customer's basement (it's a nice one), they realized I could do the job remotely. Now I just visit the customer every month or so and check into the corporate office from time to time. I'm growing a real beard for the first time in my life and most days I work in a T-shirt and gym shorts. Life is great!
Yep. Growing a beard and working in a t-shirt is the shit.
kryptto
South East, Florida
@Joshw0000 glad to hear your life change. Out of bad sometimes comes good. Covid had sooooo many bad effects. Working from home was something I did before covid, just stay focused and prioritize work. Thankfully working from home was one great thing covid did accomplish. Glad to hear your success.
313tiger
