Junkyard_Mad-Scientist
Which catch can did u get?
Cheapo made for an f150 but it had the oem fittings, figured something is better than nothing sooner than later
According to the Amazon reviews those hoses are going to crack and/or collapse soon. You might want to replace them with better quality if you haven't already. The can seems to have pretty good reviews.
Saw that toogoing to crack and/or collapse
Didn't even take the zip ties off the included hoses, went to napa and got better ones. I was sketched out using a cheapo in the first place so I replaced hoses and clamps and made my own bracket. Under $50 all inAccording to the Amazon reviews those hoses are going to crack and/or collapse soon. You might want to replace them with better quality if you haven't already. The can seems to have pretty good reviews.
Sent from my Pixel 7 Pro using Tapatalk
Take the passenger tire off - take inside passenger splash shield out of the wheel well. From there - not too bad. When you gain access to the turbos - feel if there is any wiggle in the compressor wheel - or are they tight and in place.Got an update on Downpipes from FedEx, they should be here Monday. Anyone have any tops for install. I know rear is gonna be a PiTA, so any tips would be super helpful
Use Meguires rubbing compound - and a pad applicator - unless you have a buffer. It will take them out - no need to press hard etc.Took my car to the beach over the weekend for a guys fishing trip and came back with some bad water spots. A quick wash at home wouldn't take them off so my old wax is no longer holding up. I guess I'm getting lazier the older I get, but I don't want to remove and wax it myself. I've got a couple guys outside doing it for me now from a local reputable detailing company.
Curious to see the answers, as I have somehow locked myself into the guest My Key mode. I'm in the same boat, only have one key fob and was fiddling around in the My Key settings and now have my radio volume limited to half and have found no way to Deactivate MyKey.Hey fellas I wanna get a spare I only have original key fob how does it work gettin another one dealership or no thanks guys
Similar here. Mine works fully. The wife's will only crank it. It won't unlock the doors.Curious to see the answers, as I have somehow locked myself into the guest My Key mode. I'm in the same boat, only have one key fob and was fiddling around in the My Key settings and now have my radio volume limited to half and have found no way to Deactivate MyKey.
