SM105K's SHO BIBLE/BUILDS/LIFE
Lol idk. There’s some seriously stupid torque management nannies that need to go away. But maybe it can be disabled lol
You might be on to something. There are numerous Stand Alones out there. Pro-EFI, Haltech, Fuel Tech, Motec, AEM, ect. Might be something to talk about with Brad.
Ecoboost_xsport
Sacramento, CA
Would putting Haltech in my SHO make a difference?
I was getting ready to pull the trigger on an AEM setup on mine a few weeks ago...before all that "drama"...so it's on hold for now. I was just going with the CD7, their OBDII adapter and their analog-to-digital CAN module adapter. It all started when I was trying to figure out a way to get my EGT probes logged...
I like the CD7 because it has some powerful logging capability, mostly I wanted to be able to log EGTs and be able to overlay it to logs of the current stuff I'm reading with the SCT. This device is way more capable than the SCT.
Now, as far as standalone (or even piggyback) ECUs go, what's nice about this setup is I can always grow into one. The CD7 is able to take inputs from any of the big name ECU boys, but AEM's own product line can be used as well.
I know this didn't answer your question, but I've been going down this road myself. You'll have to identify pretty much every input the factory PCM needs and wire that up to the Haltech, which I'm sure could be possible...I just don't know enough about it.
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Definitely interested in alternative routes to achieve a goal. If that means a reach around then so be it.
Bluezone
Ont, Canada
Update on the Lexus. I got it a started and running. Sure enough there is a miss. Actually there is two misses. Both cylinder 3 & 4 are missing. However, they are fired by the same coil. If you know anything about waste spark, then you might understand what it happening. I know the car has 140k miles, and I am pretty sure the coils are the originals. So I bought new coils, new plugs, an new wires. I installed them and yep...still missing.
The wiring in the Lexus isn't the best. I pulled and de-loomed the coil wires. Looking to see if anything is broken or out of place. Didn't find anything. However, there is a Haltech Triple Channel Ignitor (JDM thing) that may have failed. So I bought a replacement and when it arrives, I will install and see what happens.
On the earlier 7m-gte engines, they use a ballast resistor in circuit to batch fire two injectors simultaneously. 3 resistors 6 injectors. Unfortunately I don't recall whether or not the the 1JZ and 2JZ use the same injector wiring system. Also turbo and non turbo Motors use different resistance, resistor packs, if it does turn out to be this. Question is is it a lack of spark or a lack of fuel?
It is a spark issue. I have pulled the plugs in the dead holes and they are covered in fuel. So that pretty much narrow's it down. The Haltech runs the engine, and the Stock ECU runs everything else. The signal from the Haltech, goes to a Triple Channel Ignitor, then to the coils. If one channel on the Triple Channel Ignitor goes out, then one of the coils goes out. I am pretty confident that failed or I have some *****'d wiring.
I bolded your statement because I am in the process of learning all of that and figuring that out myself.
Bluezone
Ont, Canada
Gotcha. Is this a wasted spark system? I don't recall what style of ignition 1-2 JZ family uses or the Haltech.
Scratch that I just re-read your response and it's a triple Channel. So either one of the coils is dead or one of the big to3 transistors may have died on the Haltech. Assuming of course that the wiring between the halltech and the coil is okay.
One of the guys on the Isuzu RS Forum board was having trouble with a halltech because of an ignition driver transistor. He was managing 350 horsepower out of a 1.6 L Isuzu motor with a halltech. LOL
Yep I systematically replaced most common fail parts. Plugs, Coils, and Wires. When that didn't fix the problem, I looked at the wire harness (signal and grounds) from the coils to the triple channel. If the new triple channel doesn't fix the issue, I will check the wiring from the Haltech to the triple channel. If that checks out, then I probably have an ignition driver issue in the Haltech ECU itself. If that is the case I will send it back to Haltech.
If that doesn't fix it, then time for an LS swap!!! lol
Haha, never. I have already had boosted LS motors. It has always been a "want" of mine to have a 2J car. When I am done it will make 600hp to the tire comfortably. Just need fuel pump, injectors, and a new tune.....after I figure the miss out.
limited02
Olathe, KS
I was just teasing and the car will be a hoot once you get it sorted out!
stripSHO
Idiot Savant
Detroit
Lately I've had the hankering to do a 1UZ build. This looks damn ****, and I just so happen to have all the fixin's for a roadster laying around... https://m.facebook.com/photo.php?fb...9710&set=a.211161082576069&refid=13&__tn__=+>
Lexus Update: Got home today and started working on the clutter and wires. Reloomed and shielded most of the wires. Threw in the new Triple Channel Ignitor and WHAM! She lives! On all Six cylinders! It was too late for video tonight. When I get home from work tomorrow, I will post more pics of my attempt at cleaning the wiring up, and I will post a video of her running.
I still need to do a full fluid swap, drain a full gas tank of five year old fuel, and take her down the street. Hopefully she will be rocking the streets this weekend.
stripSHO
Idiot Savant
Detroit
That does look damn cool. You should do it.
Some day, maybe. Problem is I'm fairly stingy so it's hard for me to buy another engine and trans (would be CD009 btw) when I already have a 350 and TH400 sitting there. I'm in the slow process of consolidating my bigger and fuller garage at my other house into my already crowded 2.5 car at home. Once that's done I can start projecting again, and first order of business is to rebuild my CJ7.
Yeah I steered away from projects for the past couple of years. It was nice lol. However the Lexus just kept popping up, and for the amount of money I have spent it has been smooth sailing so far. This car is making me learn about JDM life (lol), waste spark, stand alone ecu's, and other things I have not been subjected to building American cars. I kinda want to buy a Jeep and start a build next. Been watching a lot of Matt's Offroad Recovery on Youtube, and it has spurred my interest in that side of motorsports.
Lexus Update: Re-worked some wiring, added some thermal protection, cleaned up the engine bay some more. There is still alot of work to be done. I got the majority of the old fuel out. Toyota was cool and added a drain plug. Now I have 13 gallons of five year old fuel I have slowly add to the Focus and my GF's Jetta (haha).
20211201 151552
20211201 151548
Need to change the oil, and throw new gas into her, and hopefully take her around the block today.
Check out my IG @fafomotorsports to hear her run.
stripSHO
Idiot Savant
Detroit
Yeah I'm subbed to Matt too. I wish there was more videos of idiots in crossovers getting pulled out the bottom of a canyon and whatnot lol. In October I took my truck two-tracking in the U.P. on a whim, man I forgot how much I love being out in the woods. Broke a mirror, bent my step rail, and got hopelessly stuck at 11:00 pm with no chance of escape but I loved every second of it. Felt like a kid again!
