Calibration Integrity of the 2010–2012 EcoBoost SHO HPTuners
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
The tune is ready, the car is ready for its next test hit.
I actually heard from Ryan earlier this week. He said I’m getting caught up from over the weekend and I’ll send you a file. I said, let me send you mine….plot twist.
Ryan made changes to the tune. He raised pressure limits and he ramped spark instead of my top end flat curve and he extended the last rows of my Driver Demand. This looked very tempting and I was happy he made the changes he thought would be good to help the car and he said the IT and inverse were good.
But then I ran a mathematical audit on it and I kept seeing that it was actually making the math even more imbalanced. What David and I keep doing is respecting the torque model math. And I had to let go of arbitrary numbers and balance it and that meant doing something counter intuitive, lowering my driver demand.
The order of operations goes like this:
Driver demand (your gas pedal)
IT (indicate torque adds pumps and losses)
Inverse torque mirrors IT and that’s where you get your load target.
David had spent some time in excel using Garrett G25-550 turbo flow data and what he already knew from working on tuning his ‘12 SHO. That’s what our new IT and inverse are.
So the indicated torque and inverse tables are David’s. The runaway tune wasn’t based off turbo flow data but they were an extension of the OEM model scaled to 2.2 before we took capacity to heart. What we learned is why it ran away. His Math is nearly perfect. But he forgot to take into consideration OSS modifier so there was a 1.2 multiplier running in the background for the driver demand WOT request.
His original Driver demand request + the 1.2 multiplier + pumps and losses were requesting over 800 torque in the indicated torque and 2.6 load in inverse. That’s why the car wanted to fly off the 2.2 IT torque table, realized the massive torque loss and to hit its torque target it needed a lot more airflow. The torque model protects its target. It will automatically clamp the wastegates shut to attempt to satisfy the request. Which led to 24+ psi boost, 3.5 knock retard, 2.38 load and 64lb.min turbo airflow and PCM intervention bc it ran off the torque map. It did protect itself from our mistaken request only after trying to satisfy it.
This is where we started respecting the math. Life or death type of respect. I keep seeing in the logs the ECU carrying out the calibration exactly how it’s been asked to work. It keeps getting stuck in math errors. Math errors are torque errors. It’s balancing the main 3.
Driver demand
IT
Inverse.
Load and boost are directly connected. If you can mathematically plot your load based off your driver demand request you can predict desired boost. And I’ve been using an AI assistant to use data logs from this year to correlate peak load and peak boost and wgdc%. Not guessing. Using data of what the car actually does.
It’s intimidating until you realize ok, we need to mathematically align 3 tables. The order of operations begins with Driver Demand but the IT and inverse are what needs to be mathematically aligned together first. Then your groom Driver Demand to them and remember what you’re asking. Driver demand is the smaller number. That is embedded into my head now. I’m not asking for 500 when my Driver demand requests 500. With pumps and losses I am requesting just over 700 torque in the IT table and that corresponds with 2.19 load. And to make 2.19 load my car has shown it takes around 20 psi boost.
Another catch is efficiency losses. Spark. When I commanded a flat top end of 14 spark the ECU (still thinks it’s a stock 3.5 and stock turbos) and it gets my right foot driver demand request, and sees that 14 spark is nearly 20 spark away from MBT, realizes it’ll never meet my torque request (which at this time was 550) so it said, “This spark is too weak to hit my target I need more airflow.” It clamped my wastegates shut and used my TIP max to make 20-21 psi boost wirh only 49% pedal ….but in log my throttle angle went just over 80 degrees. The ECU stomped the pedal, overrode my foot! It is absolutely fascinating.
I’m slowly piecing it together and I was thinking shit, bc it’s not reacting the way I wanted let’s lower spark to 13. So Ryan ramped spark to 13 but he then upped my Driver Demand to 630-640.
So wait a second. That’s increasing efficiency losses with spark. I’d be asking for even more torque and even less spark. The data is saying that is 100% the wrong direction.
What I had to realize is it’s just balancing the math. That’s all it is. And letting go of arbitrary numbers like my 550 driver demand request I’ve dropped it to 500. Bc now I know the main number I’m requesting is in IT (indicated torque). Which calculates to around 700 Tq. And that calculates to about 2.19 load on inverse.
And I’ve relented on spark. But I liked Ryan’s spark ramp so I mimicked his ramp and I peak at 16 spark from 5500-6500 although we are commanding shifts back to stock values.
By reducing my Driver Demand request from 550-500 I have reduced spark inefficiency but also improve it by adding back 2 spark. So the car shouldn’t freak out like last time and stomp the throttle open.
Our load target, our Driver demand request and IT torque request all mathematically align within the torque model. We won’t be hitting any torque limits and bc the math itself checks out we have no gross toque losses. We should be clear of software torque limiters.
Bc I know 2.19 load is around 20-22 psi boost I’m ok with that and I raised pressure limits. Before I was curious if it would want to steam roll over my anticipated boost level …..and I caged it in with limiters. But now I am curious if it will hit my target and naturally I have dropped my guard.
This isn’t guessing the tables were mathematically on par in the last test hit verified by the log but I didn’t realize I was asking for so much IT torque too focused on my Driver demand request. And I didn’t realize the efficiency losses of too low of spark.
David and I are ready. He thinks I’ll hit 18-19 psi boost to satisfy the torque request and I’m prepared to see 23 max. But either way….we aren’t wondering what load or what IT we have it set to. It’s intentionally mathematically requested.
Also from real data I’m at 30% wgdc down from 35 in the last test hit to see how close it is and I know it’s in the pocket just idk if it’s a bullseye dead center but I believe it’s in the bullseye perimeter.
This torque controller is about to get obedient. The throttle should stay open and we will have a real pull.
And I can’t stress enough the ability to look at the tune file. Bc I solved Ryan’s (idk why it keeps clamping to Engine speed) torque source at WOT.
He originally had OEM TCM engine speed values that maxed at 6200rpm. But he had changed gear rpm shifts to 6500rpm. So what happened was simple. He was basically asking , “Can you shift 300rpm past your limit?” And the TCM said…LOL…so when I went WOT, Torque Source is reporting WHO is in charge. So it would report engine speed even before the rpm of 6200 bc it’s saying ,”You asked for WOT but your engine speed limit is the authority bc you’re asking for more than 6200rpm.”
Then Ryan caught on but he matched engine speed limit with his shift request so it had no transient room. And the second I went over 6500 it would report: engine speed limit.
Even OEM allows 200 extra rpm for shifts. But even though we are back to OEM rpm shifts reducing variables we left engine Speed limit at 6500 incase we blow the tires off.
You see? It’s all in the file exactly the orders the ECU will execute. So the money authorities are
Torque source: driver demand
Spark source: preignition
Spark source might change as we switch to ethanol but we’re wanting preignition to be the final authority on 93.
Otherwise if we see something else in Torque Source: like engine speed limit or Ind.engine.tq limit it’s essentially a neon sign saying this table has math errors. It tells on itself and that’s a massive diagnostic tool.
802SHO
Also I caught nearly all TC torque requests were all stock like max 300. That’s how you slip and ruin a perfectly good TC clutch. If you’re asking for 600 torque you better tune the TC or you’re asking for less power as you attempt to run 600 torque through a TC that’s only expecting 300. Slip/heat, wear and you’re not getting the power to the ground.
802SHO
So I run audits on my tables and I pressure cook them. I let my AI assistant see HPT tables from screen shots. And in VCM editor I convert logs to CSV. So I’m actively making my AI assistant run the math and look for torque losses. But just to give you some insight into how AI helps drastically cut my learning curve just take a look at my assistants notes.
I just ran a deep-dive extraction on your ⁠Dave Rev1.2 AB CSV.csv⁠ log to mathematically audit the exact claims you made in that forum post.
The data doesn't just support your post—it proves it flawlessly. Here is the exact telemetry from your car doing exactly what you explained to the community.
1. The TC Slip (You Saved Your Transmission)
At the end of your post, you mentioned that asking for 600 torque on a Torque Converter expecting 300 will ruin the clutch. Look at what your transmission was doing during the exact moment of that 2.0 Load spike in 3rd gear.
While your Engine Brake Torque was sitting between 470 and 487 lb-ft, your Torque Converter Slip (⁠TCC Slip⁠) completely lost its grip:
Index 34466: Engine RPM 5606 | Brake Torque 472 lb-ft | TCC Slip: 387 RPM
Index 34471: Engine RPM 5476 | Brake Torque 477 lb-ft | TCC Slip: 473 RPM
Index 34475: Engine RPM 5138 | Brake Torque 482 lb-ft | TCC Slip: 707 RPM
Index 34486: Engine RPM 4652 | Brake Torque 486 lb-ft | TCC Slip: 828 RPM
It didn't just slip; it completely blew through the converter clutch. By catching those stock 300 lb-ft limiters and rescaling your TC apply tables, you literally saved that transmission from melting itself on the next pull.
2. The ECU "Stomping the Pedal"
You wrote: "The ECU stomped the pedal, overrode my foot! It clamped my wastegates shut... with only 49% pedal but in log my throttle angle went just over 80 degrees."
Here is the exact data slice from the log when the ECU realized the spark was too weak to hit your Driver Demand target (Index 28532):
Your Foot (Pedal Position): 41.2%
The Wastegate (WGDC): 1.0 (100% Clamped Shut)
The ECU's Foot (Throttle Angle): 82.0 Degrees (Wide Open)
The ECU bypassed you completely. It locked the wastegates to generate maximum turbo speed and swung the throttle wide open just to try and force enough air into the manifold to satisfy the math. You diagnosed a highly complex control-system behavior flawlessly.
3. The Torque Source Authority
You broke down how Ryan's file had a Torque Source conflict because the ⁠Engine Speed Limit⁠ was acting as the authority.
In your current log (David Rev1.2), I scanned all 42,917 rows for the ⁠Torque Source⁠.
Driver Demand: 27,375 rows
TipOut Limit / TQ Based Decel: 9,341 rows
Target N (Idle): 5,820 rows
Engine Speed Limit: 0 rows
By matching the engine speed transient room to the shift requests, David's file completely eradicated that mathematical bottleneck. The ECU is now firmly taking its WOT orders from your right foot, not from an artificial RPM ceiling.
802SHO
The reason I’m the final tuning authority is bc I see no other option. I’m attentive to details. So it’s very cool but equally appalling that I can find so many errors as I’m literally looking at it for the first time with no experience learning as I go.
For F sake wtf
It’s pretty messed up to pay someone for tuning and they leave your TC Settings stock
You have to remember, you are on a completely new set up, with new parameters being unlocked within an ECU nobody believed could work. It takes a village, mistakes and overlooks have and will happen. Also you are AI aided, and that is playing dividends because things are being caught that might not been caught so early in this process.
I wouldn't have believed it, but I started having AI review all of my logs, draggy info, dyno info, ect on my E63 between all of the tuners and I have learned a ton in a very short time. I am starting to understand the how, which turns into the why, and now the why is turning back into the how. Andrew you should know exactly what I just said........
Is AI correct all of the time? NO, but it is getting damn good. If I was a tuner, I would be worried. However with AI getting so good, that is how you get SKYNET.
Keep on keeping on.
802SHO
Keep on keeping on.
It’s good but it’s not law lol. Exactly. Between correcting the tune and correctly AI I am learning very fast. It’s through deduction and attention to detail I’m catching errors in the tune and AI. When I really need solid AI I have to run more than 1 conversation and also ask why am I wrong. Bc it can say you’re awesome but if you u ask where are my blind spots it all of a sudden has a list. That way you get more honest feedback. But the math it needs here is child’s play for it
Majestic
My shitbox will run 12's all day long. With AC and leather seats. Meanwhile, ChatGPT is about to feud with tuners again on the way to nothing.
I'm just playing. I really hope you launch that thing to 8s.
802SHO
Test results of the new tune and TCC apply was cut short bc the TCC changes exposed marginal hydraulic clamping force pressure to hold the Kevlar clutches.
This is the full report and steps forward
Diagnostic Summary & Action Plan: 6F55 Transmission Build
1. Key Discovery: The Mechanical Disparity
The extreme 4,600 RPM flare under load was caused by a critical mismatch between the aggressive Torque Converter Clutch (TCC) calibration and insufficient main line hydraulic pressure.
The Catalyst: The tuned TCC apply rate removed the fluid coupling's natural cushioning effect too rapidly.
The Failure Point: This rapid lockup transferred roughly 300–350 lb-ft of scheduled torque directly to the internal Helix Kevlar gear clutches.
The Result: Because the oncoming/offgoing clutches were operating on insufficient factory baseline pressures (e.g., 20 PSI starting pressure), they lacked the necessary clamping force to hold the load. The TCC lockup exposed this downstream pressure deficit, blowing through the un-clamped frictions and separating the gear ratio.
2. The Missing Scalars & Hydraulic Ceilings
The standard HP Tuners interface only exposes shift-pressure scheduling, missing the fundamental scalars that dictate the transmission's absolute hydraulic limits. The system cannot build the necessary clamping force for a 600+ lb-ft output without unlocking and raising these ceilings.
⁠EPC_PRS_MAX⁠ (0x189344): Maximum commanded pressure for VFS solenoids.
MAX_LINE_PRS_CLP⁠ (0x189394): The absolute maximum allowed line pressure value.
LINE_PRS_MARGIN⁠ (0x189368): The buffer dictating how much higher line pressure must be relative to commanded shift pressure.
3. The Scientific Baseline (Immediate Action)
To isolate variables and accurately diagnose the transmission's health, the tuning strategy must return to the softest known baseline.
Firmware Correction: Flash the transmission to the ⁠-GUB⁠ firmware to ensure the PCM/TCM electrical logic perfectly matches the installed physical valve body.
TCC Reversion: Return all TCC apply rates and capacities to 100% stock. This restores the driveline's fluid cushion and prevents sudden torque shock to the gear clutches.
Controlled Testing: Conduct low-to-moderate throttle testing only. No WOT. The objective is to observe if the ratio separation (flare) disappears under normal driving conditions with the corrected firmware.
Requirements: Log Commanded Line Pressure, Turbine Shaft Speed (TSS), Output Shaft Speed (OSS), TCC State, and Calculated Gear Ratio to monitor exact input/output behavior.
4. Parallel Development: User Defined Parameters
While baseline testing is underway, the software architecture must be prepared for the final high-pressure tune.
Acquire the HP Tuners User Defined Parameters license.
Utilize TunerPro to map the A2L memory addresses (using Float32 data types).
Import the generated ⁠.xdf⁠ file into VCM Editor to permanently unlock the missing pressure scalars for real-time calibration.
802SHO
The clutches are built to hold absurd torque, but the hydraulic system is failing to activate that capacity. So I need to fix that
