Rod bearings??
MADDOG11
Houston, Tx. Denver, home
I KNOW, I KNOW, REPOST! REPOST!! REPOST!!!
OK, 92 MTX, 190K replaceing the clutch set, RMS, oil pan gasket and sending unit this weekend. Wondering when replacing the rod bearings should I just use standard size or do I need to take a measurment to get the correct size? Thanks for the help!
Wht93MTX
Sy & Ty
Pewaukee, WI
Not to hijack the thread, but I think I may have a rod bearing issue as well. When the car is idling, a light tapping sound can be heard from the drivers side of the engine bay, but it goes away when the engine speed is changed. Also my red oil light flickered a little bit today, and the CEL came on as well. Is this a good indicator of trashed bearings?
Cocoa,Florida
stop driving it right now!
and change them before its too late!!
[Where did my first post go?]
Need more information. My oil pressure light flickered today and it didn't worry me a bit. A bogged the engine in stop and go traffic and dropped the engine speed to 400-500 rpm. The source of the noise needs to be identified and the EEC codes need to be checked. The noise could be anything from rod bearings to a loose crankshaft damper to a bad accessory belt or tensioner. Find it with inspection and a mechanic's stethoscope.
ritmusic2k
wears a tux.
Garden Grove, CA
That happens to me every once in a while too... where's the forum stethoscope?
One thing to help narrow down the search - pay attention to the speed of the tapping - a very fast tap will typically be related to the crankshaft, while a slower tapping will typically be related to the camshaft. At around idle speeds I'd guesstimate a camshaft ticking/tapping to be about 2-3 ticks/second, and bottom end tapping would be twice that speed. Fast ticking in conjunction with red oil light of death means, well... death. Best of luck on the diagnosis!
Wht93MTX
Sy & Ty
Pewaukee, WI
Well, I found out that my rod bearings are not trashed, the tapping I was hearing was from the transmission-yet another symptom of my bad throwout bearing. The sound can only be heard when the clutch is all the way out- I push it in, and the sound disappears. I think I dodged a bullet on this one.
smokin joe
Milwaukee WI
Yes do them ASAP this is mine with 197,000
Bearings003
The one that almost spun
Bearings020
If that doesnt make you want to change them i dont know what will!!
