rod bearing question
SuperHO
Mental Patient
St. Joe, MI
so how would one know whether or not one would need to go with standard rod bearings or go with undersized? I don't really have ready access to a pair of calipers, so should I stick with standard and hope for the best or what?
yamahaSHO
E85 whore
Arkansas
It is very rare that you would find a journal from the factory that had to be undersized. If your crank hasn't been messed with by anyone, you're almost good to assume standard is what you need. You can plastigauge to double-check, but I'm willing to bet that standard is all you would need.
Phoenix
SHOHOLIC
QC , Canada
what he said. :stupid:
yamahaSHO
E85 whore
Arkansas
Regrinds require UNDERSIZED bearings as the CRANK is what is undersized. Phoenix was correct.
Devin
3.Slow
Pacific Northwest
SO the +.25 are undersized bearings? Wouldn't the crank journal be the part that is undersized?
ST 2 SHO
WVA
Devin SO the +.25 are undersized bearings? Wouldn't the crank journal be the part that is undersized?
ahhh I see your point but your also missing the point
It's referring to the crank journal ( under-sized )
+ .25 is referring to the bearing from stock ( over-sized )
93rev2sev
Hockeytown
Plastiguage is hair-thick plastic that deforms under pressure. You stick a thread of this stuff on your bearing, torque the puppy down and see how much the plastiguage deformed. It will tell you your current bearing clearance.
It comes with it's own chart. Take the smushed plastiguage and compare it to the chart. When you find the line that's the same width as the smushed plastiguage, that's your bearing clearance.
When I did my first rod bearing job, I measured my rod bearing clearance with plastiguage before AND after swapping the new bearings in. I was able to tell EXACTLY how sloppy my old bearings were compared to the new ones.
yamahaSHO
E85 whore
Arkansas
Mr Anonymous
Tire Wall
Devin
3.Slow
Pacific Northwest
My bad! Sorry about that Phoenix.
Well, maybe I can still be useful. SuperHO, here's an example of plastigaging:
CRW 4881
