Rod Bearing Question
LiLGhettoSmurf
Owego, NY
Would it be my rod bearings going if I have a clicking sound coming from my valvetrain and my RPM does a random up and down 200 rpm thing all the time. And sometimes on a start up it will drop the RPM down enough to stall it out.
SHO#7
Cincinnati
Most likely no. Rod bearings make more of a knock than upper motor ticking. You may be in need of a valve lash adjustment. You also may have chain tensioner noise.
The idle issue will most likely be seperate. Maybe an Idle Air Control valve. Or IAC.
Mike
F-22 Raptor SHO
7015 feet above Sea Level
knocking and idle symptoms are two separate problems.
reset your idle before you run out and buy any type of sensor. When I do work on my car that requires battery disconnection, I will have a bouncy idle if I dont set the idle correctly. Simply hooking up the battery, starting the car and driving it will cause the idle to bounce like yours is doing.
The knocking could be from several sources, not just the rod bearings.
Valve lash ticking is rare.
Cam Chain tensioner ticking is the next thing up from valve lash
Timing belt tensioner failure for automatic SHO's is most common.
Rod bearing knock is not rare, but has other bad things associated with it like very low oil pressure indicated by the oil light coming on, and metal flakes in the oil.
