PTU oil change on a 2013 PP
Scott C.
New Jersey
I know I am most likely beating a dead horse. But I need a little guidance on trying to change the PTU oil. My first question is, since I have a PP is it an easier job and why. Second, what parts from Amazon would you suggest purchasing to get the job done. Also, is there a good youtube video on the process. I am new to this, only owned my SHO less then a year.
krewat
Long Island
If you have the temp sensor in the fill hole, it's going to be a pain. Since you have a 2013, there's no vent extension up in the engine compartment unless the TSB was done that added it.
I don't remember the specifics, someone else will be sure to comment, but I'm not sure if the 2013 had a temp sensor.
The PP should have the drain plug, but again, not sure about the 2013. So emptying it is easy, and if you have the temp sensor in the fill plug, it'll be hard to fill. Being it's a 2013, it MIGHT not have the temp sensor, so filling will be easy.
Yes 2013+ PP have a temp sensor for the PTU. It is a bit more of a pain the factory way coz the downpipe has to be removed to service.
There are a couple of ways to tackle this job on a PP without removing the downpipe. I believe there is a good writeup on this forum (Johnbigdog?), as well as on ecoboostperformanceforum.com in the HOW TO section.
Scott C.
New Jersey
You guys are great thank you...what about purchasing tools...like mini suction devices?
Sent from my SM-G955U using Tapatalk
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
I did mine the first time with a hand pump, I overfilled the PTU by about half a pint through the drain hole, then just yanked the hose and slammed the plug back in.
This time I want to try the vent method, but I don't know where the damn vent is haha.
FiveLeeter918
Tulsa, OK
I added that link, and bolded a new title within my thread. If they miss it, they are daft.
haha I know where it SHOULD be, just can't seem to find it back there. I don't seem to have that vent hose extension, though
It might be missing, just like sometime the traction control buttons are missing on some SHOs from factory.
https://www.ecoboostperformanceforum.com/index.php/topic,3836.msg79057/topicseen.html#msg79057
This part fits the vehicle you selected:
2013 Ford Taurus
SHO; Four-Wheel Drive (Full Time)
The vehicle options this part fits:
  • Fit Note: Less Version Packages, SHO Package 1
  • Production Date: 07/2012-
Ford Part No.: DG1Z-7034-F
Valve Assembly - Vent
5D2BF5B499A3579396CE5BFC02119529CBFD8E24EC7C87E5E8
Base No. 7A246
Part Description Valve Assy - Vent
Manufacturer Ford. This genuine Ford part is guaranteed by Ford's factory warranty.
Not saying you are daft. I am saying if they miss the PTU fluid change title it my thread they are daft.
My 13PP doesnt have a vent tube. It has the breather. I took the breather off, and added the fuel line and used that is fill it in my explanation. Then I put the breather back on. When I change the fluid again in 12k miles, I will add the part Shodded posted above.
313tiger
