Oil filter o-ring
toledogt
Ohio
There has been some previous threads about the seal between the block and plate where the oil filter threads into.
Does material viton, 3/32 sidewall and 2 1/2 ID sound correct? I read Mcmaster Carr has them. Or better yet does anyone have 2 extra? I might not get it right the first time. The oil drip under the car is getting worse. :stuck: Thanks
SHO U UP
SHO Guru
Virginia Beach, VA
They are 1/8" thick x 2.5 ID x 2.75 OD for the oil cooler O-rings. One is really all you do need as you really can't mess it. When you buy these they will normally come in a multi pack. I have some somewhere but when I moved alot of my stuff still sits in boxes. Someone should be able to chime in and hook ya up though. Hope that helps ya. ;)
bmytych
