Odd issues
0V3RC10CK3D
Washington
Well, I tried my first race in the new MTX, vs a 92 VW Corrado, as i'm running through gears after i pass 6k rpms or so my car starts bucking, like I'm taping the breaks every 1.5 seconds or so, anywho he passed me up, also I didn't feel any extra kick after 3800 RPM's or so, is there a way to check and make sure the b-fly valves are working?
USHOMEISHOU
Troublemaker
New Mexico
get under the hood while idling, twist the throttle and once you hit around 4k you can see the actuators open up the secondaries:thumb:
92inPA
s.e. PA
I suggest you take a close look at your plugs and wires to solve the bucking.
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
if indeed the butterflies arent moving take them apart use a dremel tool and some grease.
but the problem you speak of sounds like what the other 2 said
Bizzy
Run your codes. It might reveal the answer to your problem. :thumb:
0V3RC10CK3D
Washington
shomesomesho and I derived it to be from the TedB chip, so we took that out, I'll probably pick up a Tweecer in the next couple weeks.
