New project car unvield....
SHO_DOODmorrris
Owner & Fanatic
Alberta
Carattrackhdr
1986 Toyota corolla AE86... gutted and caged. this will be a combo drift/drag/street car. clean vins light as shit and i'm super stoked... everything is seam welded, has a huge tranny tunnel and its just made of awesome... the n2 wide body kit is gone and its just a shell now... i cant wait to start building it. ask away and i will answer what i can. and yes it will be accompanied by my Holset HX35 :evilgrin:
:evilgrin::evilgrin:
AND it will be on megasquirt
-Mitch
P.S it is now the "Hot mess garage V2.SHO"
firebat45
Edmonton
Nice, I saw that at DMCC I think. I know I've seen it before around here.
My buddy with the 240 looks to be backing out on his project due to personal issues, so I might have some parts for you if you're interested (tranny, clutch, etc).
How soon are you starting? Got it home already?
SuperHO
Mental Patient
St. Joe, MI
plan on destroying the splendid weight bias with a heavy ass V6 under the hood?
SHO_DOODmorrris
Owner & Fanatic
Alberta
He will put that weight bias back into play with all the bi***es in the back seat that he picks up in it. :rofl:
This man speaks the truth... partially.
I will be moving the firewall back about 6 inches at least so that ******* rear sump can **** of my way.... and then ill sandbag the shit out of the rear end or make sure i have 20 gal's of fuel in the back so i can hook up :p and blaine, i think im going with the ranger bell housing and the mustang t5 if that works. so yes im interested in the tranny... i know im going to blow it draggin it though. i plan to be running 500 wheel horse for drag and about 300 for drift. the P.O was running a FD Rx7 rotary and would spin the tires from a roll in third and would do a burnout without hooking up down the whole 1/4 mile... he only had a street port on less than stock boost (7lbs) 300 is even overkill for this car for drifting. and it is SO solid... between that cage and the seam welding it has NO flex... i cant wait to drive this puppie! and i also cant wait to make a new harness from scratch! i love being able to start fresh.
-Mitch
firebat45
Edmonton
I will be moving the firewall back about 6 inches at least so that dang rear sump can **** of my way.... and then ill sandbag the shit out of the rear end or make sure i have 20 gal's of fuel in the back so i can hook up :p and blaine, i think im going with the ranger bell housing and the mustang t5 if that works. so yes im interested in the tranny... i know im going to blow it draggin it though. i plan to be running 500 wheel horse for drag and about 300 for drift. the P.O was running a FD Rx7 rotary and would spin the tires from a roll in third and would do a burnout without hooking up down the whole 1/4 mile... he only had a street port on less than stock boost (7lbs) 300 is even overkill for this car for drifting. and it is SO solid... between that cage and the seam welding it has NO flex... i cant wait to drive this puppie! and i also cant wait to make a new harness from scratch! i love being able to start fresh.
-Mitch
Ranger bellhousing is part of the ranger tranny, can't run a T5 on there. Not really a big deal though because a T5 won't take much more than a M5 anyway, and that's actually debatable. There's some boosted Ranger guys running big (for a Ranger) numbers on the M5. The M5 should be fine for 300, same as T5, but 500 HP is going to be pushing both of them.
If you don't run a hood and drop PS/AC, relocate the battery, and possibly have a fuel cell instead of a tank (further back), weight distro should be pretty bang on. The V6 isnt THAT much heavier than the 4AGE, about 150 pounds.
Besides, nobody cares if it's actually 50/50 or not. It's some pointless number that people brag about. If the car handles the way you want it to, it doesn't matter what the weight distribution is.
SHO_DOODmorrris
Owner & Fanatic
Alberta
thatnks for clearing it up... well i guess ill just have to buy a few ranger M5's then... only one way to find out... plus im so much lighter and hooking up will be tough.
no ps no ac batt is relocated already and comes with a fuel cell and 255 :D
MerkXRTurbo
Vancouver, WA
I'd be apprehensive about the Ranger tranny holding up to Yamaha RPM, although I don't know much about the M5.
SHO_DOODmorrris
Owner & Fanatic
Alberta
who cares lol ithey are only 100 bucks or whatever it is at picknpull... ill buy 5 at once and get a deal or somthing. depends what im doing, mind you drifiting a good clutch kick is pretty ******* the tranny lol.
firebat45
Edmonton
Clutch kicking is for engines that can't break the tires loose on their own...
Just punch it or use the nice hydro ebrake you've got on there.
SHO_DOODmorrris
Owner & Fanatic
Alberta
picked up the shell today. pulling the enigne out of the SHO tomorrow after work and picking up a megasquirt setup this week too :) cant wait to make a fresh harness!
