jruss1601
More specifically the car is in Ford City, PA 16226. I am the second owner. I purchased this car off ebay with 97k miles. Now it has 131,608 miles. I babied this car the entire time I’ve owned it because I figured I’d own it forever, unfortunately this car needs more tools and know-how than I can provide it. The maintenance is getting too complicated and time consuming than I can give. I think it’s a great car and I put a lot of money and new parts into this car and am sad to see it go but its about that time.
The car is basically stock besides the “SHO” I put on the windshield and the reflective stripes I put in the inset SHO on the door panels and rear bumper, and the headunit. It has the tan interior with all leather power seats with no tears in them, climate control (which I love) with cold A/C , Sony Headunit with stock Taurus coin and cup holder combo below it (which I also love). All lights light up and buttons work except the volume and seek for the stock radio, obviously. This car had a single cd player and radio combo but the cd player didn’t work correctly so I removed it for the sony. CD player comes with a remote! You can have the old setup too. Moonroof works great and doesn’t plug up anymore. Car has always been a non-smoker vehicle
I have the maintenance records for the entire time I’ve owned the car, mileage and date. Among the parts, besides regular maintenance (oil and air filters), I’ve replaced are o2 sensor, catalytic converter and y-pipe, spark plugs and wires, inner and outer driver tie rods, both rear struts, cruise control recall, new water pump, timing belt and tensioner, thermostat, new a/c condenser, serpentine belt, starter, all rear brake components, e-brake, passenger inner tie rod and lower ball joint, proportioning valve, brake line distribution block, many new front brake work done, driver rear wheel bearing, gas cap and gas door hinge, 4 wheel alignment, crankshaft postion sensor, and sunroof drainage pipe cleaning.
Vin # 1FALP54P4SA208902 The carfax should be clean.
The car will come with 4 studded winter tread tires with many many miles left on them. They are basically brand new. Probably 80 or 90 percent tread still left on them. You may also get my car cover and repair manual
The Bad. Well, these are the reasons I’m selling the car.
I can no longer control the passenger side window. I disconnected it because my brothers/sisters would put the window down not knowing it won't go back up (without taking the door apart and connecting different wires). I have determined it IS a wire issue somewhere between the battery and the windown switch unless i just kept buying bad replacement switches. I have close to the same problem with the rear passenger window. You can control it when you are back there but the driver can only put it up. The rear window had done this since I bought the car. It was never a real problem for me. And i heard a good cleaning will fix that one.
Current Condition. Ok so heres what up now. Current inspection is up in December of 2010. This car is hand waxed 3-5 times a year using Meguire’s. I get compliments on the car all the time mostly from guys who used to own a SHO but I have got some guys saying how great of condition the car is in for how old it is, etc. You can PM me or call if you'd like 724-664-1692 for any more info. Thank you
