1bad98SHO
you can wire them open or delete them. If you wire them open you will have to remove the cable from the IMRC box that is on the front valve cover. What I did was remove the box. I pulled the Cable to open the secondaries and then i bolted the cable down to one of the coil packs. Eventually I ended up deleting the secondaries. If they dont open up at or around 3400 RPM the Top end suffers badly. Makes a big difference.
If you are going to either wire them open or delete them then I would suggest getting a Tune From Paul Nimz(SHOZ123) And tell him you either deleted them or wired them open and he will adjust the tune accordingly.
